1974 boler water tank - Fiberglass RV
Old 07-23-2012, 05:16 PM   #1
Trailer: 1974 Boler
Hey, can anyone help me figure out how to use my water tank...I have no clue, we just got it. Thanks
tremmert is offline   Reply With Quote
Old 07-23-2012, 05:38 PM   #2
Carol H's Avatar
What size is your Boler? I will assume you are asking about your fresh water tank? Well normally you fill it with water via an outside port and depending on how you get it out depends on if you have a hand pump at the sink or a faucet with knobs which would indicated you have a 12 volt pump that needs to be turned on in order for it to pump the water out of the tank. Sorry thats the best I can do with little info...
Old 07-23-2012, 06:23 PM   #3
Trailer: 1974 Boler
Hi Carol, we have a 13' Boler, it has a hand pump as well as a hot water faucet at the sink.
Old 07-23-2012, 06:31 PM   #4
Carol H's Avatar
Is the hand pump not working? As long as you have water in the fresh water tank the hand pump should work. If it hasnt been used in a while it may need priming or the seals in it replaced in order to work. Are you sure you have a fresh water holding tank? Some of the old bolers dont and it only works with a city water hose connected to the outside.
a Hot water faucet? You have a hot water tank on your 13' boler? In that case that tap will also not work until the hot water tank has been filled. There is normally a by pass on the fresh water piping that may need to be turned in order for the hot water tank to fill.
Sorry cant be more helpful.
Old 07-23-2012, 06:41 PM   #5
Trailer: 1974 Boler
I'm sure it works, I just don't know how it works, I've never had one before
Old 07-23-2012, 07:12 PM   #6
Roy in TO's Avatar
Chances are that the pump is for your tank and the faucet connects to the city water inlet. Follow the hoses from underneath the sink.
boler
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 7 08-02-2020 08:44 AM
1974 Boler : THE TANK - new flooring Jayson Wall Modifications, Alterations and Updates 10 07-05-2007 08:16 AM
1974 Boler : THE TANK Jayson Wall Camping, Campout Reports 10 07-04-2007 08:18 AM
1974 Boler : THE TANK - completed Jayson Wall Modifications, Alterations and Updates 0 07-02-2007 09:33 PM
1974 Boler : THE TANK Jayson Wall General Chat 0 01-01-1970 12:00 AM
