1976 Ventura Camper - Need some advice / help - Page 2 - Fiberglass RV
Old 04-12-2015, 12:31 PM   #15
Trailer: Ventura
Saskatchewan
Wonderful thanks Dudley, I just keep standing in the camper and looking at it hoping I could figure out a magical solution.
The wood is 3/4 so thinking 3/4" square aluminium tubing would do the trick. How did you bend it? Was it difficult ? I know it isnt much of an angle but how did you find it?
Also when you braced the roof was it only temporary until the aluminium was in place?
So for instance, brace the center with a 2x4 screw in the aluminium and then remove the wood?
Last question, how many pieces of aluminium did you use? There are about 5 places I feel I would want to brace to really support it.
Let me know your thoughts, and thank you so much for your guidance!
Merc1fuL is offline   Reply With Quote
Old 04-12-2015, 01:18 PM   #16
Dudley's Avatar
Trailer: 1998 Casita 17 SD
The 3/4 inch stuff bends fairly easy, I think I just put in in a vise and gave it a tug, did this in a few spots to get a gentle arc and test fit it. I think I used 3, did the one bout a fooft from the rear, one by the vent and one by the door. I think (have a great memory just real short). but that was just me, the more the merrier, the main thing is to get the roof arched again for rain run off and to brace it if stored outside in the winter.
The bracing was just a 2x4 bracing against the wood, cut it a little oversize and wedge it to force the arch in the roof or you could also use a small bottle jack and a 2x4
Old 07-09-2015, 04:58 PM   #17
Trailer: Ventura
Saskatchewan
BIG updates coming soon! - Just browsed through the forums, it appears there have been a few people around here lately refurbishing these Ventura trailers! I cant wait to get mine finished.. I think I can finally see the light at the end of the tunnel. Deadline for completion is August 14/2015. Will post pics soon!
Old 07-25-2015, 09:22 AM   #18
Trailer: Ventura
Saskatchewan
Sneak peak of what's to come!
Name:	ImageUploadedByFiberglass RV1437837330.382712.jpg
ID:	87080Click image for larger version
Name:	ImageUploadedByFiberglass RV1437837367.099099.jpg
ID:	87081Click image for larger version
Name:	ImageUploadedByFiberglass RV1437837431.516794.jpg
ID:	87082Click image for larger version
Name:	ImageUploadedByFiberglass RV1437837489.260980.jpg
ID:	87083Click image for larger version
Name:	ImageUploadedByFiberglass RV1437837522.529778.jpg
ID:	87084Click image for larger version
Name:	ImageUploadedByFiberglass RV1437837575.200108.jpg
New insulation, new wiring, moved propane tank mounting spot, supported the roof with aluminium tubing and starting to get some color on her!
Starting to see progress here!
Old 07-26-2015, 01:25 PM   #19
Dudley's Avatar
Looking good, like the teal
Old 07-26-2015, 01:27 PM   #20
Dudley's Avatar
What are the cutouts on the front for? Inquiring mind want to know!
Old 07-26-2015, 01:59 PM   #21
Trailer: Ventura
Saskatchewan
New fridge location! Interior is getting a complete makeover as well. She needs to be complete by aug 14 so once finished I'll post more pics! Click image for larger version
Name:	ImageUploadedByFiberglass RV1437940719.791424.jpg
ID:	87123Click image for larger version
Name:	ImageUploadedByFiberglass RV1437940749.702291.jpg
Sooo much work but so rewarding.
Old 07-26-2015, 02:07 PM   #22
Trailer: Ventura
Saskatchewan
The box on the front is going to house 2 6v Trojan T-105 batteries, 30amp fuse panel and battery charger.
Also installed an outdoor plug as you can see for convenience :-)
Refurbished the rock guard, replaced the old sheets with that plastic used for lean to's (spelling??). It is really strong with and has UV protection!
Cleaned all of the aluminium I could, windows, belly band, ect..
New trim on belly band and windows as well.
Old 09-30-2015, 02:40 PM   #23
Trailer: Lionel
Wiring diagram
I'm trying to fix my furnace and it's the same model as yours! Please tell me you have a wiring diagram or could possibly take a close up pic I would really appreciate it
MEDHBSI is offline   Reply With Quote
Old 06-16-2016, 10:07 PM   #24
Patricia D.'s Avatar
Trailer: 1975 Ventura
Manitoba
Ventura rebuild
Hi Shawn,
I know it is about a year ago that you were working on your trailer but I am just beginning to tackle mine and have a few questions that I hope you can answer. I am thinking of moving my kitchen to the front as well and am wondering if you think doing so has affected the weight distribution and handling of your trailer.
Do you recall how you lifted the floor? just by prying or did you cut away sections?
Thanks.
Patricia D. is offline   Reply With Quote
Old 06-17-2016, 07:04 AM   #25
I hope Shawn comes back to answer your questions. It's been a while since we've seen him: Last Activity: 10-31-2015 02:04 PM
ventura
Need some advice... Sharry B Problem Solving | Owners Helping Owners 6 09-09-2013 11:49 AM
Traveling from Green Bay WI to Columbus Ohio need some advice Kevin K Problem Solving | Owners Helping Owners 2 09-05-2013 01:33 PM
New to the site and need some advice. Trooper11 Hi, I am.... 20 06-06-2012 07:31 AM
Need some advice on window replacement Ted B. Problem Solving | Owners Helping Owners 4 08-04-2008 04:32 PM
1976 10Ft Ventura Model 400D D McComber Classified Archives 0 05-28-2007 04:50 PM
