1980s Bigfoot trailer blackwater tank - Fiberglass RV
Old 08-26-2014, 11:24 AM   #1
Trailer: 1980 17' Bigfoot
I bought a Bigfoot trailer a few weeks ago and have been busy replacing all the plumbing lines. I installed a new grey water tank and replaced all the 1.5" lines under the trailer but I have discovered that the 3" black water pipe and elbow has a hair line split on the bottom. Question is has anyone replaced their 3" pipe and if so is it threaded into the bottom of the black water tank? Can I cut the elbow and thread out the joint from under the trailer easily without having to remove the toilet and tank from above?
The previous owner apparently drove away with the sewer discharge still attached and tore everything apart under the trailer. I was really hoping the 3" pipes were sound as they looked fine but now they gotta go.
I was thinking about trying to patch the split with ABS glue on the inside and outside and a couple hose clamps but I would rater replace if I don't have to remove the toilet and tank. Unfortunately in order to thread out the pipe I would have to cut the pipe at the elbow to get past the frame when turning... means there would be no turning back.
Any advice from previous plumbers would be appreciated!
Longkilt is offline   Reply With Quote
Old 08-26-2014, 02:17 PM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
I would go the easy way first with this. Use the ABS glue as it's not a pressure line should work fine.
Old 08-26-2014, 03:59 PM   #3
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
If you can get to the hairline crack from the inside, you can repair it with the ABS glue. Clean the area well, apply liberally and let dry. I would also apply the glue to the outside. I assume the crack is on the bottom of the pipe and the only problem here will be a tendency for the glue to want to drip off.
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 08-26-2014, 04:52 PM   #4
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Melt it back together!
mszabo is online now   Reply With Quote
Old 08-27-2014, 12:02 AM   #5
The crack is on the bottom of the elbow as well as about a 24" length of 3" pipe. I should be able to get to the inside so I will try ABS solvent on both sides of crack and then tighten 2 or three hose clamps. I'll try to remember to take some pictures of the repair attempt and report back with the results. Thanks for the advice guys! I think the repair attempt might save a huge hassle of replacing pipe.
Old 08-27-2014, 01:22 AM   #6
Mike, I wouldn't use any clamps on it, remember there's no pressure on it. A $4 can of ABS glue is cheap.
Old 05-01-2015, 11:36 PM   #7
Trailer: 1985 BigFoot G
Mississippi
Wondering how it held for him? Would love to know in case we have to fix any of these things on our old one. :-)
Gardnpondr is offline   Reply With Quote
Old 05-02-2015, 01:34 AM   #8
Good question.....must have worked or we should have heard about it. Kind of like newbies listing trailers for sale and never letting us know they have been sold
Old 05-02-2015, 10:06 PM   #9
Mississippi
I sure would like an update because I might have to do something like this with mine. I'd have to cut my shower stall all to pieces just to get it out the bathroom door UNLESS I could get at it UNDER the camper. Mine sits UNDER the shower stall.
bigfoot
Propane usage (T off the trailer tank or take a spare tank) knighth001 Problem Solving | Owners Helping Owners 13 09-20-2012 06:37 AM
Blackwater River State Park and State Forest Ray N Camping, Campout Reports 10 11-13-2011 05:53 PM
13' 1980s Burro Dana T Classified Archives 1 06-15-2009 09:30 PM
Wanted: Blackwater Holding Tank for 17' Boler Dwight Burditt Classified Archives 3 04-21-2008 06:29 AM
Blackwater treatment Kevin F Care and Feeding of Molded Fiberglass Trailers 5 07-11-2006 08:39 AM
