!2/120 Volt Fridge - Fiberglass RV
Old 09-19-2017, 09:18 PM   #1
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
!2/120 Volt Fridge
Has anyone put one of these in their trailer?
Dometic Coolmatic CR-1080U/F 2.8 Cu. Ft. 12/24V DC / 110/220V AC Refrigerator / Freezer With Flush Mount Frame - Boat and RV Accessories
It says it uses 3.3 amps @ 12 volts when running and it runs 40% of the time if the temp is 86 degrees F.
I am trying to keep the gas plumbing to a minimum in my trailer and am looking at 12/120 volt fridges.
Old 09-19-2017, 10:13 PM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Alex, although I have not installed this particular refrigerator, I have installed a NOVAKOOL Danfos 12 volt only refrigerator in our 13' Scamp, using a single 100 watt Renogy solar panel hooked to a single group 27 battery, with great results.
I have also installed a 12 volt only Truckfridge (I think that this may be a rebadged Engel) Danfos refrigerator, using a single 160 watt Renogy solar panel and a group D AGM battery. I don't think I will ever go back to using an absorption style refrigerator again. I do have a 2000 watt Yamaha generator incase of several rainey days, or shadey campsites. I have been looking into wind generators for RVs just for fun, but I don't think I would go that route. Just as a side note, the people at NOVAKOOL encourages extra insulation around the refrigerator where ever possible, and I had used a combination of ridged styrofoam and reflectix.
Best of luck with your project.
Dave & Paula
Old 09-20-2017, 04:08 AM   #3
Raz
Raz's Avatar
Vermont
In terms of operation a compressor fridge is superior to an absorption in performance but 3.3 amps x 40% x 24 hrs (32 amp hrs) is a lot of charging. If you have camped here in New England you know that the public campgrounds are all in the woods so solar is limited and people don't want to hear your generator, hence quiet hours. Of course private campgrounds with hookups are always available. Or with a big enough battery you could probably go several days with out charging. For me, my Dometic 2193 absobtion fridge runs forever on one tank of propane and no battery drain at all making it the better choice for where I camp. Raz
Old 09-20-2017, 10:58 PM   #4
Gas fridge best idea. If you have propane already then use it. Having another connection is not a problem and we can run 2 years on our propane tank on the fridge. Solar may not work all the time, hence trees, clouds etc. 12V doesn't always keep them real cold. We use 12V when driving if not real hot and propane when stopped. It is hard on an alternator to use the 12V all the time so you need a heavy duty alternator. Think of future owners. It is easier to sell a trailer properly equipped.
Old 09-21-2017, 12:08 AM   #5
David B.'s Avatar
Trailer: Lil Snoozy
Jann, you are absolutely correct about running an absorbsion refrigerator on 12 volts, but the original poster was talking about a 12 volt Danfoss compressor refrigerator.
Dave & Paula
Old 09-21-2017, 09:50 AM   #6
Engel
I love my two engels, very quiet, use very little battery draw
Brentsdeal is offline   Reply With Quote
fridge
More 120 volt outlets in the Burro DuaneQ Modifications, Alterations and Updates 10 08-30-2016 07:25 PM
Small 120 volt breaker alternative? Nelmes Problem Solving | Owners Helping Owners 6 09-29-2013 09:24 AM
120 volt wire connectors Carl G Problem Solving | Owners Helping Owners 7 05-28-2010 10:45 AM
