2 burner stove top cover suggestions (U-Haul) - Fiberglass RV
Old 11-02-2013, 11:20 AM   #1
Trailer: UHaul
Massachusetts
Dear Fiberglass RV friends,
I am the proud owner of a 1984 U-Haul that I plan to get to know over the winter and then take out starting next spring. I need to learn to a lot of skills (like parking and lining up over the tow jack) before then. I have a small amount of modifications that I intend to do and look forward to spreading them out over the next few months.
I bought a hand pump for the sink, a small dish rack, a porta potty that tucks under the front seat, and now I am looking for suggestions for a stove top cover for my 2 burner stove.
I noticed after I drove the trailer home that the things that sit over the burners flew off during the drive. What do people do about that? Do you tuck them away in the over head bin? Do you use a stove topper of some kind? If so, do you have suggestions of ones that did or did not work for you?
Many thanks,
Sharon D
Sharon D is offline   Reply With Quote
Old 11-02-2013, 11:54 AM   #2
Try these guys. I have purchased many things from them at good prices.
Camco Universal RV Stove Top Cover Stainless Steel - $39.00
Old 11-02-2013, 01:32 PM   #3
Chris Jones's Avatar
Trailer: U-Haul
Sharon,
There should be clips that hold those on. I will snap a pic of the clips on mine here in a little while.
Chris Jones is offline   Reply With Quote
Old 11-02-2013, 02:33 PM   #4
Trailer: U-Haul
Originally Posted by Chris Jones View Post
Sharon, There should be clips that hold those on. I will snap a pic of the clips on mine here in a little while.
Here are the clips on mine. While towing they do not move around. Possibly your clips are there under the stove top. That's where I found mine. Took me a little while it get them figured out, but once I did they work great.
Old 11-02-2013, 02:41 PM   #5
I was missing a couple of the clips, used some small wire to hold the grates on, stove has since been removed. Before we removed the stove I had made a cover by putting sides on the bottom of a cutting board. Also see Chris' thread about the vent for another thing to check on.
Old 11-02-2013, 02:47 PM   #6
Trailer: UHaul
Massachusetts
Chris,
Thank you for the information and picture of the clips. I see where they would go, so I'll look and see if they are tucked away some place. That would make all the difference in the world, but Bob is right it would be easy enough to make a new set.
Mike installed a new vent when he bought the U-Haul, so I think it works well, but I will check on that as well.
Old 11-02-2013, 03:09 PM   #7
LOL, I think Mike gave me his stove clips, or maybe it was some extras he had. We traded some stuff between us as we are only 25 miles apart. I never actually saw his Uhaul. Today we are visiting our daughter in CT, a friend of hers stopped by, and while discussing future camping plans she mentioned an acquaintance has a Uhaul. Not a member here she thinks.
Old 11-04-2013, 05:50 PM   #8
This is my approach to the stove top cover situation.
Since I have the bed set up full time, I don’t have a dining table. Standing while eating works only so long. Time for a solution. I have designed a cutting board to serve triple duty: stove top cover, food prep counter, and dining table. Pics are attached.
I bought a wooden cutting board from that official Scamp supplier store; Walmart. It is about 21" long x 15" wide. I sealed it with food safe salad bowl finish from a woodworkers store. (Much like a clear stain).
I then cut four, 2" long, 1"diameter dowels and used clear silicone to attach them to the bottom corners of the board (15 ¼" apart and 11.5" deep). I positioned them so that the right rear side dowel would go between the grates and the other dowels extending beyond the stove, resting on the counter top keep the board from shifting when traveling. I put a dab of silicone under each dowel leg to help keep it from shifting.
I then drilled two holes ½’ deep for two 10 penny (10d) nails 1.5" long with heads removed, and pressed them in the holes at one end of the board. These pins are the anchors for the table to attach to the top of the frig.
I also drilled and put in a nail in the center of the board at the other end that holds the support leg. I then drilled two holes in top of frig to correspond with the pins in the board.
When finished prepping and cooking the meal, be sure the frig door is locked shut with the little knob. I then face the end of the board with the two pins towards the frig and drop them into the holes at the top of the frig. At the other end of the table, I place a support leg placing the end over the single pin to keep it in place.
The table is 28.5 inches high so just about the same as a regular table and can be used from either left side with a chair pulled up to it, or while sitting on the front couch.
Bone appetite!
Metal pins in bottom of board for attachment to refrigerator.jpg   Metal Pins on other end of board to hold support leg.jpg
Holes in top of refrigerator doorfor table pins.jpg   Table in position with support leg.jpg
Scamper Jim is offline   Reply With Quote
Old 11-04-2013, 10:06 PM   #9
Trailer: Chalet
Send a message via Yahoo to Lynn Musgrave
The stove cover/table looks very nice.Good thinking I like it when things can do double duty.
Lynn Musgrave is offline   Reply With Quote
Old 11-05-2013, 07:39 AM   #10
Scamper Jim, Most excellent.
Old 11-05-2013, 08:07 AM   #11
tractors1's Avatar
Trailer: Escape 21 - Felicity
There's a combination stove top cover/cutting board/serving tray toward the bottom of this page:
Photo-Gallery
Charlie Y
Charlie Y
tractors1 is online now   Reply With Quote
Old 11-05-2013, 09:48 AM   #12
Trailer: UHaul
Massachusetts
Ooh, lots of smart solutions. Thanks for sharing.
Old 11-05-2013, 09:50 AM   #13
Name:	Aug  2012 025.jpg
Name:	Aug  2012 027.jpg
Name:	Aug  2012 029.jpg
Name:	Aug  2012 031.jpg
To keep plate grates in place I installed small round magnets (2 under each grate) Had to grind a bit off each foot to keep level.
Built a stove cover to go over stove top, installed a couple if inserted magnets here also on the inside sides to hold down.
Have not had any problems with grates jumping off since.
Ron
RRJR is offline   Reply With Quote
Old 11-05-2013, 12:11 PM   #14
djtriceflt's Avatar
Trailer: 1985 U-Haul CT-13
Home brew craftmanship!
Wow, great innovations, thanks for sharing!
don '85 CT-13 PEACE be with you!
"Sometimes the hunt is better than the catch"
djtriceflt is offline   Reply With Quote
u-haul
Suburban 2 burner stove top - repair or replace? Ricksan Modifications, Alterations and Updates 5 07-22-2013 05:14 PM
Two-burner stove cover? Bobbie Mayer Problem Solving | Owners Helping Owners 11 05-27-2011 02:02 PM
Stove cover suggestions? Roger Harshaw Problem Solving | Owners Helping Owners 3 04-21-2009 05:39 PM
WANTED-3 burner stove top Christi V. Classified Archives 2 03-20-2009 06:45 PM
stove top cover Christi V. Modifications, Alterations and Updates 24 07-06-2008 06:11 AM
