2000 17' Burro water heater "Anode" - Fiberglass RV
Old 04-06-2014, 11:00 PM   #1
Trailer: in the market
Kansas
I'm spinning my wheels trying to find an anode that has electrical
connections rod is 4 inch in length
I need to cover the end with water proof boot
I could change the wiring to fit
Mine is a Atwood G6A-7 gas/electric...but most G6A-7 are gas only
I thought that's strange
Found some water heaters gas/electric $400
Goofy web leads you in circles
Mine reads 75 Ohms...read it should read 12-14, that maybe misleading
Have some ideas posted for me to check out at this site,but strange
it worked before I drove back home.
Maybe I should go back to square one and check out all the circuits
Heater was set at 90 degrees when I bought it, I was still in Calif
and I set it up to 150 degrees worked great...got home now it
will not heat...I checked the reset button...it's position is in, I'm
baffled
When I fill the propane tank I guess I can see if it works with propane
I like the idea of gas/electric option.
Suki is offline   Reply With Quote
Old 04-08-2014, 04:28 PM   #2
Joe MacDonald's Avatar
Post pictures if you can, it sounds like someone added a cartridge heater element like a hot rod or lightning rod to a standard water heater. The anode being referred to would not have wires on it. An anode is a piece of zinc compound that is designed to be dissolved by the water before it rots or eats your tank, and is threaded into one of the bungs on the tank
Joe
Old 04-08-2014, 05:31 PM   #3
Kansas
Joe
May have been a drain plug and some one installed
a cartridge heater element.
Maybe I should have said heating element
My hot water heater is a electric/gas (propane)
most are now propane only.
I found an electric/gas for $400 plus...they are becoming rare I read.
Mine is shaped like an anode and the terminal has two male prongs
that the cord fastens to.
Not like most that have two threaded screws with a U shape rod.
It's possible somebody added it, if so they did a nice job.Click image for larger version
Thanks,Gene
I looked at cartridge elements and that's what it looks like,only it looks like original installation.
Old 04-09-2014, 04:08 AM   #4
If you pull the cartridge. Out and check it over carefully you may find a part number on the element that you can look up on line or start googling cartridge heaters until you find the right one
burro
Casita water tank anode Ed in Pensacola Problem Solving | Owners Helping Owners 3 12-06-2010 05:41 PM
Suburban hot water heater anode difficult to install Steve M. Problem Solving | Owners Helping Owners 7 05-25-2009 07:22 PM
Anode Rod for heater.. Christi V. Care and Feeding of Molded Fiberglass Trailers 4 04-20-2008 09:25 AM
anode rod JHJohnson Problem Solving | Owners Helping Owners 2 08-07-2007 07:59 PM
An ideal anode removal tool Legacy Posts Modifications, Alterations and Updates 4 10-28-2002 02:38 PM
