Originally Posted by Crackedegg
What epoxy do you use Robert?
Thanks. I was thinking of using the West system for the wood block gluing. How many blocks do you use for the upper cabinets. In my Boler 17' there is a bunk bed/storage area. Do you think Epoxy is strong enough to hold a bunk? I wouldn't think so but I haven't tried it either.
For attachment of the
scamp wood bunk mount which I am doing I have a suggestion for using West Marine 6 10 epoxy, comes in a caulk tube with a mixing nozzle.
After the wood is epoxied to hold it in place and fill any gaps between wood and FG the other thing done is "tabbing" it in with a few inches of FG and resin used as a tape. Layed along the wall and over the wood. Wood floor to FG sides are attached this way in
Scamp and I think
Boler. Maybe others.
Might apply to your bunk arrangement. Do have to peel back the ensolite or rat fur a bit to have access to apply FG attachment directly to the walls but it is very strong.
