3 way fridge not working - Fiberglass RV
Old 07-12-2015, 06:53 PM   #1
Trailer: Ventura
Saskatchewan
Hello FBRV,
I am hoping someone can help me out here. I am remodeling a trailer and putting a new Dometic 2354 3 way fridge, they fridge has just came in and I wanted to plug it in to see if it works.
So I plugged it into a 120v outlet and nothing happened.
Any ideas why this is? Does it need to be hooked up to the gas lines and 12V DC to work?
Any help would be appreciated. Thanks!
Merc1fuL is offline   Reply With Quote
Old 07-12-2015, 07:50 PM   #2
Trailer: 2003 Casita 17' SD
Duluth,Minnesota
How long did you leave it plugged in? Nothing noticeable happens when you plug it in but several hours (or more) later you should start noticing it getting cooler. Try leaving it plugged in overnight and then see if it cooling or not. Make sure the thermostat is set correctly and you should be good to go. You should not need it hooked up to gas or 12v dc for it to work on 120v.
Randy Hagen is offline   Reply With Quote
Old 07-12-2015, 08:28 PM   #3
Bob Miller's Avatar
As mentioned, this type of refrigerator takes a considerable amount of time to start cooling. I suggest putting a gallon of cold water in the unit and monitor the temp of the water, not that of the air inside the refrigerator.
ALSO: It appears that this refrigerator also requires 12 VDC to operate the energy selector system. Here is a clip from the manual.
12 Volts DC Connection
This refrigerator model require a continuous 12 volt DC
supply to maintain the automatic energy system.
The connection is made to the positive (+) and negative
(-) terminals of the terminal block on back of the refrigerator.
(See FIG. 1). Correct polarity
I don\t know if it will default to 120 operation if there is no 12 VDC and no LP applied.
Above all, be patient... if it is a new refrigerator, it will work, Dometic is very good about quality control.
Old 07-12-2015, 08:57 PM   #4
rbryan's Avatar
Arkansas
Almost all 3 way fridges require a 12v DC connection in order to power up, especially if they're AES. If the control board doesn't sense adequate input voltage, it won't turn on.
Old 07-12-2015, 09:18 PM   #5
tractors1's Avatar
Trailer: Escape 21 - Felicity
Control board does need 12V to run and sense energy source. If no 120V then it sends out 12V to the propane gas solenoid to open that.
Charlie Y
Old 07-13-2015, 09:03 AM   #6
Trailer: Triple E
Here's a little note to Dometic fridge owners. The newer fridges have a heater inside the freezer compartment door opening. This is intended to prevent the freezer door from freezing shut. The problem is, that as long as the fridge is receiving 12 volts, this heater is on, 24/7. If you are off grid this can flatten your batteries in two or three days. There is a switch in the upper casing of the door opening. If you are off grid I recommend that you slide it to the off position. This shuts off the heater.
Gerry Kiernan is offline   Reply With Quote
Old 07-13-2015, 09:35 AM   #7
Bob Miller's Avatar
Dometic Refrigerators
"Almost all" might be a stretch, especially with many of the smaller units installed in FGRV's. I have had at least 6 Dometics in the past 10 years and none of them required 12VDC to operate. I usually don't even bother connecting the 12VDC circuit when installing them.
But, that said, always read the instructions before trying to make one work, some will require a 12 VDC connection.
Old 07-13-2015, 10:02 AM   #8
Trailer: Triple E
Many of the older models, particularly the smaller units, do not require a 12 volt source, as they run on a propane pilot light. This pilot light will be on as long as the fridge is in operation. But, many of the newer units have a control panel that regulates the cycling of the fridge, and ignites and turns off the pilot light. These units do require a 12 volt source or they will not run.
Old 07-13-2015, 11:33 AM   #9
floyd's Avatar
Ditto!
Old 07-14-2015, 03:58 PM   #10
Dan Meyer's Avatar
Here is a link to probably more detail than you really wanted to know about RV 'Fridges: http://www.rvdoctor.com/2004/02/rv-a...on-basics.html
-- Dan Meyer
Old 07-14-2015, 04:45 PM   #11
Raz
Raz's Avatar
If the controls are inside the trailer then the fridge most likely requires 12volts to power a control board. Figure about 1/2 amp battery drain to run it. Raz
Old 07-14-2015, 06:20 PM   #12
The Minimalist's Avatar
Louisiana
What is your outside temperature. Absorption refrigerators have been know to vapor lock when cooling is initiated at high ambient temps. The solution is to turn the unit off and try again when the outside temp bottoms out at night. And, be patient.
Clif
The Minimalist is offline   Reply With Quote
Old 07-25-2015, 09:13 AM   #13
Trailer: Ventura
Saskatchewan
Thank you everyone for your help, sorry it takes me so long to reply but have been busy working on it. It needed a 12v connection to work. The manual that came with the fridge was not that helpful but you all are.
Thanks again!
fridge
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
2 way compressor fridge vs 3 way propane aimeelightsey General Chat 9 05-20-2011 05:56 PM
3way fridge not working on 12V Rick G Problem Solving | Owners Helping Owners 28 03-31-2010 10:44 AM
Fridge not working... Is it worth trying to fix it? Rob Carmody Problem Solving | Owners Helping Owners 6 09-06-2008 03:08 PM
Fridge not working all the time Karen Fisch Problem Solving | Owners Helping Owners 7 05-01-2006 07:25 AM
