3 Way Fridge Temp - Page 4 - Fiberglass RV
Old 06-22-2016, 03:01 PM   #43
Trailer: Currently shopping
propane refrigerator cooling problems
If you are not getting your refrigerator to cool correctly try a trick that was shown to me a number of years ago by an RV refrigerator repair guy. I have used the trick on a number of friges and more than 80 percent of the friges come back to life. As it was explained to me over time the little passages in the fridge gets clogged up. The repair guy told me to take the unit out of the RV, and stand it upside down on a flat surface for two hours, Then lay it on the right side for another two hours, Then on the left side.. Then stand it up and let it sit for at least four hours.. Then put the AC voltage to it and see if it cools. It has worked for me. The RV repair guy even had a fixture that he would do this with. I understand that turning it let the blockage move away from the places it is holding up the cooling material. The system sounds kind of crazy but it works as I have talked to some other RV repair guys and they say for a cheap check if you need a new unit or not..
Arizona3313 is offline   Reply With Quote
fridge
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
3-Way Fridge vs AC DC Fridge? Krista Modifications, Alterations and Updates 44 04-14-2016 06:34 PM
7 way plug to 4 way plug back to 7 way plug immrbill Problem Solving | Owners Helping Owners 3 08-10-2015 11:08 AM
2 way compressor fridge vs 3 way propane aimeelightsey General Chat 9 05-20-2011 05:56 PM
Expected hi temp tomorrow... Doug Mager General Chat 14 04-13-2008 08:35 AM
