3M Adhesive Stick-A-Stud - Fiberglass RV
Old 04-20-2018, 09:50 AM   #1
Patricia D.'s Avatar
Trailer: 1975 Ventura
Manitoba
Has anyone had any experience with these "peel and stick studs requiring no drilling. 3M VHB adhesive backing sticks to most clean flat surfaces (except wood). Accepts all marine dome snap buttons."
I am thinking of using them them on the outside of my trailer rather than making holes and am wondering if the adhesive is really strong enough to stand up to repeated use.
Patricia D. is offline   Reply With Quote
Old 04-20-2018, 10:33 AM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I use 3M VHB tape whenever possible, but I use the type designed for outdoor use (even inside). Contact 3M and they can answer your question, as it might not be designed for outdoor use.
Dave & Paula
Old 04-20-2018, 11:52 AM   #3
Trailer: 2008 Casita 17 SD
I guess my first question is what exactly will they be used for?
Old 04-20-2018, 01:12 PM   #4
its the male side of an upholstery fabric snap.
Old 04-20-2018, 01:32 PM   #5
Manitoba
Thanks for your responses.
They are sold as marine hardware so I have to assume they are fine for outside.
I am trying to design an alternative to the metal/plastic rockguard originally on the Ventura front window. I would like to make a reinforced fabric cover (outdoor or marine fabrics) that will become an awning when camping but need something to secure the cover well on the sides of the window. I would use these with heavy duty dome snaps, also marine grade. Since these are available in white, they would not be too noticeable when the cover is in awning mode. Alternatives would be 3M industrial white velcro which uses the same backing or metal stud type grommets put into the window's metal frame with holes along the edges of the fabric.
Old 04-21-2018, 11:02 AM   #6
Trailer: '79 Boler 1700
Manitoba
I live in Winnipeg, Manitoba. We have had some extremely cold winters here. Several years ago I purchased a bra system with a winter front for my Jeep Wrangler. The winter front snapped onto the front of the Jeep with these snaps. The male part was mounted on the surface of the Jeep and the female part of the snap was on the quilted fabric cover that went over the grill. I used this system for almost a decade with no problems. It survived the weather and the car washes. I think it's worth trying.
CA Douglas is offline   Reply With Quote
Old 04-21-2018, 12:47 PM   #7
Manitoba
Thanks Carol. Since, in relative terms, we are almost neighbours, that is as good a test for my planned use I could have hoped for.
Old 04-21-2018, 02:59 PM   #8
Trailer: Leocraft 26 M/Home
Where yto buy?
[QUOTE=Patricia D.;693949]Thanks for your responses.
I am trying to design an alternative to the metal/plastic rockguard originally on the Ventura front window. I would like to make a reinforced fabric cover (outdoor or marine fabrics) that will become an awning when camping but need something to secure the cover well on the sides of the window. I would use these with heavy duty dome snaps, also marine grade. Since these are available in white, they would not be too noticeable when the cover is in awning mode. Alternatives would be 3M industrial white velcro which uses the same backing or metal stud type grommets put into the window's metal frame with holes along the edges of the fabric.[/QUOTE
Patricia, can you advise where you purchased these, or if online sourcecd a link or actual name to search. I've never seen or heard of these but have several uses I'm considering!
Ridenfun is offline   Reply With Quote
Old 04-21-2018, 03:46 PM   #9
Manitoba
Online at Outdoor Fabrics Canada. They have all kinds of goodies though a bit pricey.
I have not ordered these yet so cannot speak to the customer service or shipping costs and I could not find them elsewhere online. Perhaps Carol knows another source.
Old 04-21-2018, 07:53 PM   #10
Manitoba
I have no source info. The snaps came with the bra kit for mounting purposes. I can't remember where we got the kit and I don't know the brand name. The stud looked just like the ones in the kit though.
Old 04-24-2018, 12:02 AM   #11
Use the keywords "YKK Snads". That is one of the more widely available brands of this item. Yes they do work, you can see videos on youtube about installing them from the Sailrite company. They are adhered with 3M VHB tape which comes preinstalled on the back of the fittings. There are several styles, some are all plastic and others have a metal snap fitting on them. The flexible disc with metal snaps and stud fittings can be ordered with a clear color or white base. The clear base makes for a minimal looking application versus the larger solid plastic pieces. For fiberglass gel coat you just need to clean the surface with alcohol. On other surfaces you may need to apply a primer from 3M before you stick them in place.
In Seattle I can walk into the store and buy them off the display rack at "Fisheries Supplies" in the Fremont neighborhood.
Old 04-26-2018, 06:18 AM   #12
Manitoba
Caution, do not use this vendor.
I was just about to order from this online company when I came across a BBB report indicating that they are not accredited and customer reviews state that orders have not been sent but money has been taken. I am surprised by this since the website is substantial and has the feel of a legitimate business.
I will post information if I can find another source.
Old 04-26-2018, 06:45 AM   #13
Manitoba
K. Corbin, do you know anything about this brand ? The description states that they use an adhesive 3M backing,not specifying VHB. Most reviews are positive with proper preparation being the crucial element. Less pricey than the snad.
FIA HK108 Marine Stick-A-Stud
Old 04-26-2018, 07:04 AM   #14
Furthermore, google reports that:
This server could not prove that it is www.outdoorfabricscanada.com; its security certificate expired 194 days ago. This may be caused by a misconfiguration or an attacker intercepting your connection.
I would guess they closed down but left the website up.
1 5/8" metal stud with spray foam? frazzledazzle Modifications, Alterations and Updates 18 06-24-2014 10:26 AM
stud finder Mike Magee Jokes, Stories & Tall Tales 7 08-11-2013 05:03 PM
5 Stud Circle template james kent General Chat 7 04-29-2008 04:18 PM
5-Stud Wheels Donna D. Problem Solving | Owners Helping Owners 5 09-10-2006 02:44 PM
Recipe: Hot dogs on a stick Charles Watts Camp Cooking, Food & Recipes 5 04-14-2006 06:38 PM
