4 cylinder auto - Page 2 - Fiberglass RV
Old 10-09-2015, 12:20 PM   #15
Talking
I am doing the Outback just for the weight limit difference... so don't have to worry that I am too close to the limit. Thanks.... this whole thing came up because it did not occur to me that there would be a difference in weight limit... so they are being very nice to let me trade it back!
Carolyn N. is offline   Reply With Quote
Old 10-09-2015, 12:41 PM   #16
MC1
MC1's Avatar
Originally Posted by Carolyn N. View Post
Thanks to both of you! what quick responses from this group!
So the vehicles you are both talking about are 4 cylinder? Yes and I guess you are supposed to go 45 MPH anyway!
Many modern 4 cyl engines these days are quite capable. Many who use them on this forum towing glass eggs are driving 55 to 60 MPH when towing without issue. Set up is key.
Old 10-09-2015, 04:47 PM   #17
Dbybe's Avatar
Trailer: Happier Camper HC1 pulled with a 2011 Subaru Outback 4cyl CVT
Towing with my Outback
I too looked at the Scamp to tow with my Outback but I looked that the "trailer weights in the real world" chart and it kind of scared me away. I looked for a trailer that would be closer to the "hot weather long climbs" recommendation by Subaru of 1350 lbs. I did not quite make it. The HC! by my estimate is about 1500-1600 lbs loaded. I weigh the tongue weight each time to make sure I am under the 200 limit. I am at 160 give or take a few each trip.
The 4 cylinder outback has plenty of power. (Though it would not hurt to have the 6 cylinder) On the steeper climbs I shift the CVT into manual mode and down shift. This makes it a bit easier to keep the revs up. Since I am confined to the two right lanes I generally fall in with the trucks and am driving below the posted trailer speed limit of 55. In the flats 55 or more would be fine, so I set the cruise control around 58-60. Downhills I turn off cruise and use the paddle shifters to downshift to use engine breaking.
I have a couple of trips posted about towing with the Outback if you click on my name above.
Dbybe is offline   Reply With Quote
Old 10-09-2015, 05:29 PM   #18
It might be helpful to Suburu owners, as well as HC-1 wannabees, if you could get an accurate real world weight and post that value.
Old 10-09-2015, 05:37 PM   #19
Dudley's Avatar
Trailer: 1998 Casita 17 SD
I know the difference between the Legacy and the outback is the fifth gear and the final gear ratio. They also have larger diameter tires. I towed with both a 2001 legacy auto and a 2003 Outback manual and found the outback revved higher at highway speed. Of course the newer ones may be different. I did find towing our old Ventura @1700lbs was a chore, wasn't the weight but the flat frontage of the trailer. Anything you tow WILL have to have brakes and a brake controller in the car. I think the towing capacity of the 2001 legacy was 2000 lbs with a 250 lb tongue weight and the 2003 outback was 3500 lbs and 250 lb tongue weight.
Old 10-09-2015, 05:38 PM   #20
Trailer: 1988 Scamp 16
Maine
We tow a 1988 Scamp 16 with a 2004 Toyota Tacoma 2.7 L 4-cylinder with 180, 000 miles on it. It is an automatic without an extra transmission cooler. Last winter we did 4 months from Maine to Florida...lots of big hills (okay, mountains) in PA, WV, GA, TN. The going was slow uphill...maybe 55 mph...but, the rig behaved and the truck wasn't overworked. I'd estimate the Scamp weighed-in at 2, 200 lbs and we had two people and 400 pounds of stuff in the truck. I would not recommend pulling more than this.
I realize we are talking apples and oranges here but, I'd suspect you won't notice much difference when pulling with the new vehicle as opposed to the Forester. If vehicle weight, gearing, and engine size are the same you will likely see about the same performance while towing. Pack light, drive sanely!
maineboatstuff is offline   Reply With Quote
Old 10-09-2015, 05:56 PM   #21
Trailer: Triple E
Check to see if the vehicle you are getting has a "Tow/Haul" feature. It can make a big difference. It changes the shifting RPM and acceleration to match the load.
Gerry Kiernan is offline   Reply With Quote
Old 10-09-2015, 07:26 PM   #22
Radar1's Avatar
Name: Dave (and/or John)
I believe the Outback should be fine on those hills with the 13' Scamp. Ours is a 16' Scamp so we are close to the 2700 lb limit when loaded for travel, but the Outback handles that load pretty well on our hills in GA, TN, and NC.
I was considering taking the Outback out West this year, where they have some pretty steep grades, but it was time for the timing belt change which I didn't have time to do before the trip, plus we were taking a whole lot of "stuff" that made our Dakota a better choice for that trip. I do have to reconfigure the Scamp when using the Outback so I can get the tongue weight lower (remove one of the propane tanks, move extra weight to behind the axle, etc). I would be more willing to tackle those big hills out West if I was towing just a lighter 13' Scamp, but I'm sure the Outback would handle it as long as I followed the manufacturer's limits for towing at high temperatures on steep grades.
John-Dave and Marilyn
Sharpsburg, GA
04 Dodge Dakota V-8 and 17 Dodge Durango V-6
radar1-scamping.blogspot.com
Old 10-09-2015, 08:44 PM   #23
Radar1's Avatar
Looking at the Subaru website, the current Subarus with the CVT have a tow/haul/snow mode. My 08 Subaru basic old fashioned 4 speed auto has a "Sport" mode that should be used for towing.
Sharpsburg, GA
Old 10-13-2015, 03:27 PM   #24
IllAnnoy
Originally Posted by Darral T. View Post
I pull with a Nissan Frontier 4 cyl. I personally would not pull anything larger than my 1800lb 13' Scamp. If you enjoy hearing a motor "labor" up the hills in Tenn. then it probably wouldnt matter. It does to me. FWIW, mine is also a manual shift. I personally would not drive this truck and pull my trailer if it was an automatic.
Most 4CYL gasoline engines are short stroke which means slower piston speed at high RPM compared engines with a long stroke It is precisely this feature which makes them work so well with a manual transmission on hills and towing, don't be afraid to drop a gear or two and keep the R's up on those TN hills.
Old 10-13-2015, 05:37 PM   #25
IllAnnoy
The "real world" weights are not much more than an admonition against overloading.
I have a friend who's trailer's actual weight as equipped(front bath) from the factory was 1700 pounds, his "real world" weight was over 2600 pounds on a Scamp13!!
That is not a real world weight THAT IS OVERLOADING!
The empty weight as factory equipped would make a much more fair comparison.
For instance... A base Scamp13 without a package will surely weigh less than a base HC-1. with what ever standard boxes come with it.
I suggest two things....
1] The manufacturer's estimates are the best starting point.
2]Learn to travel without concrete lawn ornaments or Lucy's boulder collection.
Old 10-14-2015, 08:16 AM   #26
Your friend, Floyd, may have thought he had plenty of capacity because he only knew the dry weight and GVWR, not realizing that his heavily optioned trailer had an as-built weight much closer to the GVWR.
In my perfect world, the build sheet would list the base price and base weight of the particular model/layout. And every option box would have both a price and a weight. At the end I'd get both a bottom-line price and an as-built weight. A printout of the build and weight data would be affixed to the inside of the trailer. It would also include the GVWR and cargo capacity.
Okay.. maybe not perfect... how about new and improved?
Old 10-14-2015, 09:25 AM   #27
honda03842's Avatar
Name: Norm and Ginny
The reality is you only know your weight when your loaded and ready for the road.
Once loaded I weight the tongue weight. I pressurize the tires to cold pressure, in my case 50 psi.
My tires sit on 2x6 boards in our yard. I measure the length of the tire patch area. The length is proportional to the weight on each side. If the lengths and tire pressures are nearly equal, the weight is nearly equal on each side.
I then weight the tongue.
This is my once a year process and tells me everything I need to know about my trailer's weight.
I simply drive my loaded trailer to the transfer station every year before we leave and measure the weight by driving thru the scales.
In some sense it's kind of silly because in the years we've traveled in our Scamp 16, trailer weight and tongue weight have barely moved, 2400 lbs on the axle and 200 pounds on the tongue.
It's of course possible to do this when you first get your empty trailer.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-14-2015, 09:36 AM   #28
Yer right Floyd..... Ya know when I first decided to pull a trailer with this truck, I also talked with the local Nissan dealer's service rep. I've known him for awhile and I trust what he tells me. Anyway, I was laying out the scenario for pulling a 1750 lb Scamp and how I had taken care of the truck over the years...bla bla. Then he tells, me, "Well, let me tell you, you're going to have to get use to hearing that engine rev!". Problem is, I never have!
4 Cylinder vehicle towing, power and millage. carsonjk Towing, Hitching, Axles and Running Gear 27 05-01-2011 11:01 AM
towing w/ 4 cylinder vehicle Dawn SW Towing, Hitching, Axles and Running Gear 9 04-05-2008 07:50 PM
Towing 16' with 4 cylinder Arline Lovell Towing, Hitching, Axles and Running Gear 43 10-23-2006 11:49 AM
Is a 4 cylinder honda CRV usable for towing with? Dale662 General Chat 3 05-16-2006 09:48 PM
towing w/ 4 cylinder vehicle Dawn SW Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
