5 lug spare tire mount - Fiberglass RV
Old 03-25-2014, 10:12 PM   #1
Nevada
I plan on replacing my axle with a dexter 45 with brakes and a 5 lug bolt pattern. For those who have done so, how did you solve the spare tire mounting problem?
solarscamp13 is offline   Reply With Quote
Old 03-25-2014, 10:56 PM   #2
FTTRV's Avatar
Trailer: tp
Most spare tire mounts only use 2 bolts to hold wheel and tire on.
chuck
Old 03-26-2014, 07:41 AM   #3
Trailer: 2014 Escape 21
Virginia
I think scamp sell a metal plate with 3 long mounting studs for the 5 lug rims. (Call them.) You cut off your two current studs and through bolt the new mounting plate on the back wall. The lower back wall of a Scamp has a big piece of plywood molded into the wall for support.
Eddie
Old 03-26-2014, 07:45 AM   #4
IllAnnoy
Five bolt Scamps use three bolt tire mounts. One way to make the conversion would be to make a bracket using a steel plate with the three bolt pattern. Scamp uses one bolt at the top and two at the bottom.
Then shorten the two exiting bolts just enough to use them to fasten the new bracket to the Scamp through two holes in the bracket..
The pattern is 5"X4.5" . You can make the pattern using a piece of thin cardboard on your new axle's hub.
This idea would avoid the need to drill new holes through the hull.
Old 03-26-2014, 12:41 PM   #5
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I know you didn't ask, but FYI:
Five lug wheels says at least a 3500 pound axle to me....if so, I hope you understand that the trailer's going to ride really rough. A Scamp 13 isn't heavy enough to compress/use the cushioning parts of a Torflex axle that size.
Old 03-26-2014, 01:29 PM   #6
IllAnnoy
Actually almost all newer axles are 5X4.5 lug pattern. Using Scamp for example... The 2200# axle on the thirteen has been 5-Lug for many years.
Old 03-26-2014, 10:17 PM   #7
I just throw the spare in the back of my tug when I go camping. It's not like it's back there 24x7. Besides, it kinda reminds me to check the tire pressure....
Old 04-03-2014, 05:50 AM   #8
Timber Wolf's Avatar
North Florida
I am doing the 4 hole to 5 hole axle swap, hopefully next weekend after the axle gets here. My plan is to make a triangular plate that bolts to the existing top bolt and the cut-off lower bolt. The plate will have two more bolts attached to it to catch two holes in the wheel. My plan is to leave the top bolt long enough to go through not only the new plate but the top hole in the wheel as well. I hope this makes sense and I think it should work as I am going back with the same size wheels/tires, just with a 5 on 4.5 pattern. I can always go back through the trailer if this does not work so I am not out anything by trying it.
Old 04-03-2014, 09:49 AM   #9
David Tilston's Avatar
This is what Princess Auto sells in Canada for your application:
Heavy Duty Trailer Spare Tire Mount | Princess Auto
Stripped lug and lug nut? FlyboyTJ Problem Solving | Owners Helping Owners 2 07-04-2012 10:55 AM
Hunter I Spare Tire Mount? vjbcello Problem Solving | Owners Helping Owners 8 04-10-2012 09:05 PM
spare tire mount ScottG Problem Solving | Owners Helping Owners 0 11-06-2010 01:03 PM
scamp 4 lug spare tire mount pic? andy vaughan Problem Solving | Owners Helping Owners 11 12-31-2008 12:30 PM
Spare Tire Mount Johnathan Gallant Problem Solving | Owners Helping Owners 4 06-10-2008 06:40 PM
