5-Stud Wheels - Fiberglass RV
Old 09-09-2006, 02:33 PM   #1
I recently returned from a hot rod show/swap meet and while there I picked up a really cool plastic template for measuring 5-stud wheels. I know there's been discussion on the forums about what bolt pattern a member's trailer wheel has and several members have assisted by giving methods for measuring (Tires n Rims). But this template is so easy to use. I traced the plastic template, scanned it in, placed the numbers, created the PDF and placed it in the document center.
You'll find it here: Manuals - Axles and Running Gear
To use it, just print it out at 100%, poke holes through the four circles at the top 4 3/4,
4 1/2, 5 1/2, 5 and the larger center circle. Place one of the studs through one of those holes and start rotating to see what circles line up. You may have to try all four holes to find out precisely what pattern the wheel has. Slick.
I'm on the hunt for a 4-Stud template
Old 09-09-2006, 04:29 PM   #2
Looks good, Donna.
When you print this make sure you are set to print it at 100% size. Anything else and will not get good results.
Old 09-09-2006, 05:01 PM   #3
Brian B-P's Avatar
...You'll find it here: Manuals - Axles and Running Gear
Donna, that was the link for the related discussion topic again, I think you meant to put in Manuals - Axles and Running Gear
Also, remember to cut out the centre hole as well as the bolt holes, so you be able to get the template on past the protruding hub enough to reach the studs.
Old 09-09-2006, 05:30 PM   #4
Duh Thanks Byron and Brian! I fixed my original post to reflect the things you guys caught!
Old 09-10-2006, 06:37 AM   #5
Trailer:
Here's a custom FGRV template I've made for 4- and 5- stud hubs.
Those PCD diameter templates are very useful, but they depend on the accuracy with which they've been made. If you just 'poke' the holes on a paper-based template, it's very hard to be sure if it measures accurately.
So I prefer to measure the PCD directly with a tape or ruler. For a 5-stud hub, a conversion is needed between the measurement taken and the real PCD - I've included that on the first page of the template.
Andrew
Old 09-10-2006, 02:44 PM   #6
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
Thanks Andrew. Very useful and well done template.
Fiberglass on 4 Wheels Mac B Modifications, Alterations and Updates 12 11-19-2009 07:47 PM
5th wheels.. looking/ want to buy Christine P Wanted: Molded Fiberglass Travel Trailers 3 06-03-2009 11:58 AM
wheels jmacchi Problem Solving | Owners Helping Owners 9 01-19-2009 01:24 PM
5 Stud Circle template james kent General Chat 7 04-29-2008 04:18 PM
Wheels Legacy Posts Problem Solving | Owners Helping Owners 4 08-07-2003 08:07 PM
