5th wheel bathroom water damage - Fiberglass RV
Old 09-17-2006, 03:40 PM   #1
Paul and Libby Smith's Avatar
Trailer: 1994 19 ft Scamp 19 ft 5th Wheel / 2001 4wd 6cyl Silverado
I recently tore the side wall and bathroom (same wall) out because of water damage from the shower,inside the bathroom I removed the toilet, and in the process I accidently tore the leatherette upholstery material on the front wall, behind the upholstery material is the aluminum foiled insulation.I would like to replace the material with something more substantial,I sure could use some help on this one Paul Smith Orlando Fl
Paul and Libby Smith is offline   Reply With Quote
Old 09-18-2006, 06:48 AM   #2
You want to change the insulation or the wall covering??? If you want more insulation, would it be possible to do a double-thickness? You certainly don't want anything that could hold moisture.
If it's the wall covering, I think the new Scamps use a formica-like stuff Maybe you should contact Scamp and see if there's a newer Scamp 5th wheel in your area to view
Old 09-19-2006, 06:45 AM   #3
Thank you Donna for your response, I will call scamp, and see what they got going in the formica dept. Paul Smith Orlando fl
Wheel Weights with Bathroom Scale Pete Dumbleton Towing, Hitching, Axles and Running Gear 6 05-20-2009 12:18 PM
Wheel Bearings and Hot Water Heater Lisa M. Care and Feeding of Molded Fiberglass Trailers 10 03-11-2008 11:58 AM
scamp fifth wheel bathroom Paul and Libby Smith Modifications, Alterations and Updates 1 10-26-2007 06:32 AM
Does this look like water damage? Rebecca H. Problem Solving | Owners Helping Owners 14 07-16-2007 11:14 PM
5th wheel front bathroom Legacy Posts Problem Solving | Owners Helping Owners 3 06-28-2003 06:30 PM
