6 ft axel bearings - Fiberglass RV
Old 08-04-2014, 02:33 PM   #1
thunter's Avatar
Trailer: 2008 16ft Scamp
Georgia
6 ft axel bearings
I do not know if it has been covered before. I have a 1984 16 ft scamp . With what I think is original axle. I replaced both inner and outer bearings. Both bearings fit a 1/1/16in axle . Some older 16 ft have larger inner bearing. Some 13 ft use the same bearings. The good news is I bought bearings races and seals . The seals did not fit . Had put new seals earlier. I bought at tractor supply for $40.00. I hope info helps some one else. thunter
thunter is offline   Reply With Quote
1985 "20 ft Bigfoot tandem axel" 19ft 5'er? $6200 Robin G Referrals: Molded Fiberglass Trailers 0 02-14-2010 11:09 AM
Converting a 13' Boler to a tandem axel Dominique Towing, Hitching, Axles and Running Gear 7 08-18-2008 05:52 PM
Axel from 2005 Trillium Outback Curtis F. Classified Archives 0 01-18-2006 01:07 PM
High lift axel Chris C General Chat 7 12-05-2005 05:30 PM
Trailer-Axel Modification - Need to Haul ATV Legacy Posts Towing, Hitching, Axles and Running Gear 9 06-14-2003 12:18 PM
