7 pin black hot wire - Fiberglass RV
Old 06-05-2014, 07:06 PM   #1
Ramsey's Avatar
Trailer: 16' Scamp
Wisconsin
Hopefully someone can shed some light on my question. I just had a brake controller installed on my scamp and in the process had a 7 pin TV plug added to connect with the trailer. I now have trailer brakes. Installer also wired in the hot black wire which i believe is normally used to charge the trailer battery while in transit?? I do not have a converter/charger in the Scamp. What purpose does the black wire serve in this instance. Any light as to what i have going on would be appreciated.......
thanks, Ramsey
Ramsey is online now   Reply With Quote
Old 06-05-2014, 07:16 PM   #2
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
It is wired to the + side of the trailer battery and you take the white ground and splice a wire to the - on the battery. If you don't have a battery then it will not be wired to anything on the trailer side.
Rick Mooyman is offline   Reply With Quote
Old 06-05-2014, 08:56 PM   #3
Ramsey's Avatar
Trailer: 16' Scamp
Wisconsin
Thanks Rick for your response. So you are saying to splice or tap into the white wire in the trailer wiring and run it to the negative post on the trailer battery and that is all that is necessary to enable charging?
Old 06-08-2014, 06:12 PM   #4
Manitoba
Old 06-08-2014, 08:20 PM   #5
Robert Johans's Avatar
Trailer: Nest Caravans
Though the POLE positions may be correct, my experience with 7pin wiring tells me that the color coding on Rick's illustration could be confusing and is not exactly indicative of the trailer's WIRE colors that I have seen.
perhaps not universal, nevertheless here are the 7 wire colors and applications of all the trailers I have worked on:
Black = 12vdc + (power)
White = 12vdc - (ground)
Green = running and taillights
Red = left turn signal and brake lights
Brown = right turn signal and brake lights
Blue = electric brakes
Yellow = auxiliary
Hot Hot Hot!!!!! Steve Hammel General Chat 7 06-10-2013 06:40 PM
Changing from 6 pin to 7 pin on truck - how?? Shelley Towing, Hitching, Axles and Running Gear 4 07-28-2009 10:45 PM
Flat Pin vs Round Pin Connectors Legacy Posts Problem Solving | Owners Helping Owners 7 04-07-2003 11:34 AM
Blue wire on 7 pin connector shows 12v all the time ? Mikeny Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
