7 WAY PLUG WIRE - Fiberglass RV
Old 07-13-2018, 08:51 PM   #1
Trailer: PARKLINER
7 WAY PLUG WIRE
I had my 7 way plug wire hook up drag the pavement and rub 2 wires into. Is it ok to cut the cable/wires and splice them all back together and wrap with electrical tape. I took it to camper world to replace the whole cable and they did not know where the end hooked into the box in the parkliner 2017. So i guess i will try to repair.
Billreedred is offline   Reply With Quote
Old 07-14-2018, 05:41 AM   #2
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
Bill, I would say you have two options:
1. Best approach: Order a complete new 7 wire cable with 7 blade connector, and wire into the "box" that you mentioned "camper world" couldn't figure out.
2. Splice the damaged wires using weatherproof crimp splice connectors, then cover the whole wire bundle with split loom tubing.
-John
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Old 07-14-2018, 05:45 AM   #3
third option
Actually, there is a third option: Take your camper to any reputable trailer shop. This is a simple repair. Amazing that "camper world" wouldn't be able to figure out how to wire in a new 7 wire harness.
Old 07-14-2018, 05:48 AM   #4
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Not a problem, go to Youtube they have many videos on how to repair.
Old 07-14-2018, 04:18 PM   #5
Little House Customs <http://littlehousecustoms.com/store.html> has replacement plugs (7 Pin Replacement Plug (Trailer End) for $7.99.
Morgan A is offline   Reply With Quote
Old 07-14-2018, 04:58 PM   #6
Trailer: In the Market
Virginia
Why I love this site... so many intelligent, knowledgeable, caring individuals!! fiberglassrv... the BEST!!
mbbear is offline   Reply With Quote
Old 07-14-2018, 06:30 PM   #7
7 blade plug at your local auto parts store $5 (NAPA, etc)
Old 07-30-2018, 08:01 PM   #8
You can repair it yourself, but watch some YouTube videos on the proper methods first.
Markz is offline   Reply With Quote
Old 07-30-2018, 09:04 PM   #9
John in Santa Cruz's Avatar
Trailer: 2014 Escape 21, 2002 Ford F250 7.3 Diesel 4x4
if the wire dragged and ate through the rubber sheath, I would NOT attempt to repair, I would replace the whole pigtail (wire + 7 blade plug) to keep it weather tight and road worthy.
follow the cable into your trailer. somewhere, it goes into a junction box... disconnect the trailer battery, AC, and solar (if any) before working on this wiring. take lots of photos and/or draw a diagram before or while taking things apart, so you can put it together the same way.
if the pigtail cable disappears inside the trailer (not uncommon with fiberglass RVs), you might opt to cut it off about a foot from the trailer body, and get one of these pigtails with a integral junction box... slice open the foot long stub of factory cable, seperate out the wires, trim them to optimal lenghts, strip and crimp marine ring-terminals onto them, and secure them to this new external junction box, which you bolt to the inside of the trailer A-frame...
https://www.amazon.com/Lavolta-Trail.../dp/B01FWIFS24
Charge battery while towing on 7-way plug jeroen Electrical | Charging, Systems, Solar and Generators 27 10-18-2017 09:23 PM
7 way plug to 4 way plug back to 7 way plug immrbill Problem Solving | Owners Helping Owners 3 08-10-2015 11:08 AM
Bargman Plug Purple Wire Conundrum fusedlight Towing, Hitching, Axles and Running Gear 3 04-20-2014 03:45 PM
yellow wire/brown wire deryk Electrical | Charging, Systems, Solar and Generators 24 01-01-2013 06:34 PM
cost to have 7 wire rv plug installed in tow vehicle? Brian1 Towing, Hitching, Axles and Running Gear 3 08-18-2009 01:27 PM
» Trailer Showcase
AbelEgg
TWelch
ECO
Suanne
