7100 BTU Domentic AC shroud - Fiberglass RV
Old 08-26-2016, 03:14 PM   #1
Trailer: Big Foot 1500
Utah
It's a Dometic, Duo-Therm, Brisk Air, 7100 BTU. Came with our 1996 17' Big Foot, and now these shrouds are discontinued. Online for hours, and all similar shrouds are larger. Any ideas where I can find one?
Laurence Parker is offline   Reply With Quote
Old 08-26-2016, 03:52 PM   #2
IllAnnoy
Originally Posted by Laurence Parker View Post
Came with our 1996 17' Big Foot, and now these shrouds are discontinued. Any ideas where I can find one?
Over the years I have been in many RV shops around the country.
The places which do A/C repair almost always have a stock of reconditioned units and shelf full of used shrouds.
Old 08-26-2016, 04:08 PM   #3
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
Might try eBay too, you never know.
Old 08-27-2016, 01:40 PM   #4
Trailer: 1999 Casita 17' SD
Ohio
Last year I had no trouble finding a shroud for my 1999 Casita's Brisk Air 7180 btu unit
Do you have the Dometic number.
Here's one on e-bay that says pre 2000.
Polar White Replacement Shroud for Dometic Duo Therm AC Brisk Air Models | eBay
Old 09-01-2016, 07:41 AM   #5
Utah
ac shroud found! Thank you.
A small dealership had a new / old stock shroud "in the back". Thanks for your replies.
Old 09-01-2016, 10:34 AM   #6
IllAnnoy
Now that you have your new shroud...
When you install your new shroud...
1] discard the old fender washers which were used to install the original shroud.
2] go buy a length of 2" wide aluminum flat stock.
3]cut it to make two pieces the length of the top of the shroud.
4] drill holes in the aluminum to fit over the mounting bolts.
5] install these "full length washers" using the original acorn nuts.
This will provide a secure fit and prevent the shroud from cracking around the washers and being blown off onto the highway.
Old 06-10-2017, 11:00 AM   #7
Utah
Shroud found
Thanks to those that replied to this request. Fix has been completed.
bigfoot
A/C Shroud Replacement Needed '97 Scamp AJB Modifications, Alterations and Updates 7 12-09-2014 10:26 AM
A/C Shroud Solution Ami P Problem Solving | Owners Helping Owners 10 06-01-2013 08:30 AM
7000 BTU heater adamp Classified Archives 2 01-05-2007 09:45 AM
