'72 Boler American door issues - Fiberglass RV
Old 05-18-2012, 10:26 AM   #1
Trailer: Boler American
I've had my Boler for a week. Still looking everything over and the front door is a pretty good mess. It's got the common sagging issue and seems "full" or inflated at the bottom. It also needs new hinges/parts as there is a lot of rust.
Tips/recommendations for the bulging bottom of the door?
Also, is it enough to get new hinges from Scamp or do you need to get the "fix" as well to help with the sag?
Misha is offline   Reply With Quote
Old 05-18-2012, 03:08 PM   #2
LukeP's Avatar
Iowa
have you seen these links? these are regarding a waterlogged door - others will have to respond on the hinges. good luck!
Water In Door
Warped Scamp Door
LukeP is offline   Reply With Quote
Old 05-18-2012, 03:34 PM   #3
Water In Door
Warped Scamp Door
This is very helpful; thank you!
Old 05-18-2012, 03:55 PM   #4
LukeP's Avatar
Iowa
you're welcome! you may have discovered this, but under "search" menu, you can choose the Google search box at the bottom of the menu. You may find more links than the ones I'd saved in my favorites regarding this!
Have you bought your Boler American recently?
Old 05-18-2012, 04:24 PM   #5
I bought it last weekend and I'm hooked! This site has a wealth of information. Which is good as mine needs ALOT of work. I'm getting ready to have the propane lines checked for leaks and have the wheel bearings packed. Anything else urgent you'd recommend? My Boler has nothing remaining on the water system (other than the holes in the sink for the faucet), so I'll be lookinf for tips on getting that set up too
Old 05-19-2012, 09:21 AM   #6
Roy in TO's Avatar
For the door, it might be body sag. Check your frame and floors first. Then look under the trailer at the hinge side of the door. Chances are the small piece of plywood that connects the body to the frame is missing or has come loose.
I fixed mine by installing an aluminum frame around the door. In hindsight I would suggest fixing it utilizing the screen door mod. I'll post a link to all my fixes and mods in your other post New proud owner of '72 Boler, 13'
Old 05-19-2012, 09:25 AM   #7
Roy in TO's Avatar
I've looked at the picture of your door:
http://www.fiberglassrv.com/forums/a...2&d=1337204596
It does not really look all that bad.
boler
Ice box door issues Brian E Moon Modifications, Alterations and Updates 2 08-11-2011 12:37 PM
72 Boler American Greg H Classified Archives 9 02-06-2011 11:16 AM
1974 Boler door issues Jayson Wall Problem Solving | Owners Helping Owners 1 04-23-2007 10:32 PM
