73 trillium fridge - Fiberglass RV
Old 05-27-2009, 06:59 AM   #1
Trailer: 1973 13 ft Trillium
have a 73 trillium and was told i have to make sure the fridge is level before i operate it, but wasn`t told which way to level it, is it just front to back or do i have to level it both ways ?
thanks , Garry .
Garry Vanderzwet is offline   Reply With Quote
Old 05-27-2009, 07:25 AM   #2
Daniel V.'s Avatar
Trailer: '74 Trillium 1300
Found this in one of the manuals here...
When the trailer is stationary for a period, it must be level so that the refrigerator can operate properly. When the trailer is being parked, therefore, the level should be checked, preferably by means of a small bubble level placed on the ice-tray shelf, and the position of the bubble observed. If necessary, the level of the trailer should then be adjusted so that the ice-tray shelf is [b]level from side to side, and from front to back.
When the trailer is on tow, the continuous rolling and pitching movement will not normally affect the operation of the refrigerator, but when the trailer is parked for more than a short period, the sensitivity of the refrigerator should be remembered.
Daniel V. is offline   Reply With Quote
Old 05-27-2009, 09:58 AM   #3
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
I've always tried to level our trailer using a bubble level in the freezer compartment floor, keeping as close to that 'inner circle' as I could. Seems to work well. thus far....
Old 05-27-2009, 11:51 AM   #4
thx for the help, i`ll try that then . garry .
Old 05-27-2009, 11:52 AM   #5
thx , i`ll try that then . Garry .
Old 05-27-2009, 12:49 PM   #6
Daniel V.'s Avatar
In fact, what I ended up doing is levelling the fridge once, then adding extra stick-on levels outside the trailer to match the fridge level (instead of the trailer) so I wouldn't have to go look inside the freezer compartment when I set up the trailer. Keeping the fridge door closed as much as possible also helps maintain the inside temperature, especially with an older unit that doesn't recuperate as quickly as it should.
fridge, trillium
Trillium Dometic 211 Fridge Upgrade... Anyone? Josh Henderson Modifications, Alterations and Updates 22 10-23-2013 09:12 AM
LP fridge Perry Mac Donald General Chat 8 03-19-2010 09:22 PM
3 way fridge from 1973 Trillium Terry Toffelmire Classified Archives 5 05-26-2009 08:20 AM
Trillium Dometic RM 211 Fridge Up-Grade Info Needed Josh Henderson Problem Solving | Owners Helping Owners 2 10-30-2006 05:10 AM
Fridge Legacy Posts Problem Solving | Owners Helping Owners 15 08-09-2003 12:28 PM
