74 Hunter I resto pix - Fiberglass RV
Old 05-17-2010, 09:15 AM   #1
Trailer: 1974 Hunter I
Here is some pix of my Hunter project.
shell off of frame frame before cleaning
harold f is offline   Reply With Quote
Old 05-17-2010, 09:20 AM   #2
frame after cleaning and painting
Old 05-17-2010, 09:22 AM   #3
poptop roof off
Old 05-17-2010, 09:27 AM   #4
poptop roof off
sanding old paint off
Old 05-17-2010, 09:31 AM   #5
Hunter I logo found under paint windows removed
Old 05-17-2010, 11:13 AM   #6
Trailer: trailswest campsterl, 1996 Scamp 16 foot
Idaho
Harold Wow !! you have made some fantastic progress. I have high admiration for those of you who do "frame off" restorations. I am fairly competent at interior mods cabinets, doors, etc. but the thought of a "frame off" restoration strikes fear in my heart. I have visions of the trailer body sitting on the floor of the garage with the frame proped up against the wall for months before I could get up the nerve to take the next step. I will be particularly interested in the window install as I may need to replace the front window on my Uhaul soon. Do you plan to restore the logo and leave it on display or will it vanish on the completed trailer? The logo is a neat touch. Lee
Lee Senn is offline   Reply With Quote
Old 05-17-2010, 12:23 PM   #7
Joseph Domingos's Avatar
Trailer: Hunter Industries
Send a message via AIM to Joseph Domingos Send a message via Yahoo to Joseph Domingos
Some impressive pics Harold, WOW on the frame off work! My hats off to you as well, I don't think I'm brave enough to do such an invasive remodel, at least not at this point...
And what a find on that label under the paint! Looks like they'd even created a logo of sorts for the line or something... Are you planning on trying to keep that intact or what?
Keep up the good work & great pic-sharing!
Joe
Joseph Domingos is offline   Reply With Quote
Old 05-17-2010, 08:11 PM   #8
Hey Lee. I am going to try and salvage the logo but I damaged it some with sander before I knew what it was.Put a little aceone on it and used a razor scraper to get a lot of the paint off after I saw it .The frame was not too bad to get out .I used a small floor jack,lots of blocks and also concrete blocks and heavy boards to go across. Took quite a while to get bolts that hold shell to frame out.Soaked them overnight with marvel mystery oil and most came out but some broke off. Put ss bolts going back in.Used vice gtips on nuts below and 1/2 electric impact inside shell to remove old bolts .. I pretty much had to take frame out because the frame had cracked where the a-frame joined to the rest of the trailer and someone had welded 2" angle into it but they couldn't get to topside where it needed it most. I welded in lots more braces to stiffen it up.When I pulled it home it was awful "bouncy". Hopefully this cured that problem.
You should not be afraid to tackle yours,just make sure you get the gas line and any other thing out that goes through shell bottom.You can do, a lady on here named Francene did her CII and she also did most (maybe all) of the work herself!!! The screws on the inside ring of the windows were hard to come out had to try several phillips sizes to find the right one. Had to use a small torch on a few before they would come out,Its not too bad, the inside ring comes off pretty easy after u get the screws out. I was afraid the window was going to fall out so I had aprop on outside but it takes a good bit of work with a putty knife ect to get the old seal to break aloose.Good luck .Harold
Old 05-17-2010, 08:16 PM   #9
Joe
Good to hear from you again Joe.Yea I have been busy lately (just about every day). Helped my neighbor cut firewood today so didn't get to work on Hunter.Have kinda put the canvas thing on hold for now.Yea I am going to keep the logo,will have to do smoe work to it.Think I should keep the original colors Joe? Thanks,Harold
Old 05-17-2010, 10:59 PM   #10
francene's Avatar
Trailer: 13 ft Compact II
Good to see your photos, harold. You have done an amazing job so far. That paint would have been a huge challenge for anyone.
Great looking job on the frame! You are making huge improvements. It looks so much better already.
Fran
74 Compact II
francene is offline   Reply With Quote
Old 05-18-2010, 01:17 PM   #11
Robert Johans's Avatar
Trailer: Nest Caravans
You know, that logo can be replicated and a new decal can be made easily. I've made new decals for both my Scamp and Perris Pacer.
Old 05-20-2010, 10:07 AM   #12
Fran
74 Compact II
Hello again Fran!! Sorry for not getting back to you quicker,have been working on things around home that I have gotten behind on and haven't worked on Hunter or gotten on computer in a couple of days. Went to TN river yesterday. Thanks for the compliments. I was getting ready to send you a message to ask you about the seal or moulding that holds the glass into the alum. frame of the windows and seals the glass. Not the seal that goes between the window and camper but the one that goes around the glass. Checked with local camper places and Glass Doctor and Havent had any luck. Will be quite a while before I am ready for it but I am just checking around for it.Macmaster Carr may have it.Still have a lot more sanding to do,kinda dreading it ,Ha !!Have a GREAT DAY!!! Harold
Old 05-20-2010, 10:12 AM   #13
Hey thanks Robert.How did you make the decals? I had thought about just painting in the missing places but that may not look good. Thanks,Harold
Old 05-20-2010, 10:29 AM   #14
One of my "skills" is that of an graphic artist. I can relatively easily duplicate your logo with a drawing program and send you a file. This file you would submit to a decal company like http://www.carstickers.com/
They then produce the decal and ship it to you. If you're interested, send me an email with a close-up photo of the logo now on your trailer and I'll make the art for you.
Hunter II on ebaymotors.com Vickie B. Classified Archives 1 08-24-2009 01:58 PM
13' Hunter I Dana T Classified Archives 1 06-15-2009 09:23 PM
Hunter 1 Nancy L Musters Problem Solving | Owners Helping Owners 1 06-14-2009 09:53 PM
Our 75 Boler resto also Debbie H Modifications, Alterations and Updates 5 03-24-2008 01:41 PM
Hunter 1 (Compact II ?) Legacy Posts Care and Feeding of Molded Fiberglass Trailers 24 05-13-2003 09:14 PM
