77 Surfside door catch - Fiberglass RV
Old 10-02-2007, 06:15 AM   #1
Trailer: 1990 Bigfoot 5th Wheel
My interior door catch has been, ah, "modified". I cannot tell what the original situation was. Can someone with a Surfside post a picture of the stock setup? Please and thank you.
Old 10-03-2007, 05:33 PM   #2
Trailer: 1978 Surfside
Did anyone ever get you a pic? asking because I could use a pic of this too, as my catch has the same problem
Kent
kentj is offline   Reply With Quote
Old 10-03-2007, 06:25 PM   #3
Patience, it's only been a bit over 24 hours.
Old 10-10-2007, 06:12 AM   #4
Hmmm, looks like door catches are a weak spot; it appears that no one has a stock set-up. When daylight hits, I'll get a shot of my setup and perhaps the collective intelligence can guess the correct manufacturer.
Old 10-10-2007, 05:22 PM   #5
Sounds like an idea, I'll do the same but I'm sure my set-up isn't much good.
Old 10-11-2007, 07:23 AM   #6
The catch has been flattened; I can't tell what it originally looked like. Anyone recognize the door latch? Where to get a new catch?
Old 10-11-2007, 11:44 AM   #7
ericmarlo's Avatar
Trailer: '77 Triple E Surfside
Cam,
That is identical to my Surfside Latch. I have no problems with it other then the actual moving piece inside is old and wearing down leaving very much for it to "hook" on or go behind - meaning when I drive it always seems as if I am looking out the side mirror to make sure and feel good that my door is indeed closed.
ericmarlo is offline   Reply With Quote
Old 10-11-2007, 05:27 PM   #8
Here are some pics of mine which is in need of some work.
any ideas would be great!
Kent
Old 10-12-2007, 06:26 AM   #9
didn't some of the models of Boler use the same lockset? And I'm thinking it's no longer available
How about this? Door Lock, Bargman L66
Found a couple of previous discussions on the Bargman locks:
Door Latch - Lock Seized
Door Lock, any ideas of how to modify a 1978 locking system
Old 10-12-2007, 06:49 AM   #10
Wow, Donna, you are a font of information, as usual. Luckily, my locking unit is still working, albeit it moving slightly in the fibreglass. My catch has been hammered flat, and as Eric says, the bolt can move and slid off of the catch. I assumed that, originally, the lock bolt would slide into an opening, and wanted to see what the original catch shape was. I have the quick and dirty solution of a lock on the outside of the door, which prevents the door from opening during travel. Thanks all.
surfside
Boler Cabinet Door Catch / Latch Replacement Mike Roho Problem Solving | Owners Helping Owners 3 09-20-2020 12:44 PM
Catch and release deer hunting Rick kl Jokes, Stories & Tall Tales 3 09-03-2009 01:44 PM
Trillium Door Catch Problem Joan D Problem Solving | Owners Helping Owners 8 06-09-2008 08:19 PM
Triple E Surfside door hinges wanted Cam A Problem Solving | Owners Helping Owners 6 06-10-2006 08:54 AM
