81 casita overhaul - Fiberglass RV
Old 07-27-2013, 09:03 AM   #1
Trailer: casita 13
81 casita overhaul
I am in the middle of a total restoration of my 81 casita and was wondering if any one could help me with a few questions? I have removed all of the interior components,carpet and flooring, and was seeing if any one has a way to remove the foam from the carpet that is left on the walls,most of it has been scraped off with a scraper just need to get off the remaining stuff. A wire brush on a grinder or is there a solvent that can be used? Also I need to rebuild my windows and need to find where I can get trim for them, they are the plexiglass slider ones. Any advise would be appreciated.
Thanx Gator
Gator is offline   Reply With Quote
Old 07-27-2013, 09:10 AM   #2
Green Frog's Avatar
Trailer: '83 Burro
Virginia
No personal experience with your situation, but I would try a product called Goo Gone™ if I had the same challenge.
Froggie
Green Frog is offline   Reply With Quote
Old 07-27-2013, 09:24 AM   #3
Trailer: 2014 Escape 21
Virginia
Doug
On Scamps the old glue gets brittle and a twisted wire brush on a 4-4.5" grinder works fairly well. I have had to remove the glue from a late 90s Casita in a fairly small area. It appears they used a mastic type glue to hold on the foam backed carpet which was still soft and tacky. It was a real PIA to remove. I started with the twisted wire brush and then tried different solvents.
Good luck
Eddie
Old 08-04-2013, 06:54 PM   #4
Trailer: 84 16' Casita
I used a torch and then peeled it off. The wire brush on a grinder just spread fiberglass dust and made me itch.
Jeff in OC is offline   Reply With Quote
casita
Badly beaten Burro in desperate need of attention and overhaul aws140 Modifications, Alterations and Updates 13 03-14-2013 07:54 PM
Boler Overhaul Kat Problem Solving | Owners Helping Owners 3 08-07-2011 01:25 PM
ARCHIVED: 13' Casita need overhaul Tim 972 Classified Archives 12 03-28-2011 03:54 PM
Starting Cosmetic Overhaul Tirah General Chat 10 06-02-2006 09:56 AM
