'84 Burro 13' bearing and seal numbers? - Fiberglass RV
Old 02-21-2013, 02:32 PM   #1
Trailer: Burro 13'
Ohio
Anyone know these numbers: inner and outer wheel bearings and inner and outer grease seals? Thanks,
Tom
TomZ is offline   Reply With Quote
Old 02-21-2013, 08:16 PM   #2
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
My SWAG both 1" or maybe 1-1/16". I'm assuming you've got a 1500 or 2000 lb. Henschen. Hard to find info on this. 3000lb. Henschen has 1-3/8" inner and 1-1/16" outside. Only one grease seal--the inner. There is an embossed plate on Henschen axles which at least gives the capacity but certainly no specs on the spindle or bearings. If you can't find out, you might as well pull the hub and get the numbers off the bearing cages.
Old 02-21-2013, 09:40 PM   #3
Perry J's Avatar
Trailer: 16' Casita
NAPA stores can measure your seal and find you one by the measurements alone.
Old 02-21-2013, 10:00 PM   #4
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Yep. God only knows. Get the numbers off the bearings, and take the seals in to be measured. Any half competent parts store should be able to do it. If they start drooling on themselves, ask them for the book and a caliper and do it yourself. If they hand you one that's kind of close, but not quite right, they're being lazy. Slap them and tell them to keep looking.
Old 02-24-2013, 09:10 AM   #5
Trailer: Burro 13'
Ohio
FOUND THEM: "Timken/1 in. straight trailer wheel bearing kit with seal 203025, cotter pin, grease pack and 2 SET14 (each set contains cone L44643 and cup L44610)"
Autozone P/N BT100
Timken/1 in. straight trailer wheel bearing kit with seal 203025, cotter pin, grease pack and 2 SET14 (each set contains cone L44643 and cup L44610) (BT100) | Trailer Bearing | AutoZone.com
$21.99 per wheel an my location.
Cleaned everything up, heated the races in the oven at 450 for hour, drove them in with an appropriate sized socket. Used Mobil 1 synthetic grease..
Old 02-24-2013, 09:59 AM   #6
Tractor Supply has them packaged and displayed in the trailer section.
Old 02-24-2013, 10:25 AM   #7
rabbit's Avatar
Delaware
Glad you found the correct size. Why would you heat the races before seating? Heating won't make them smaller. I must be missing something here. Wouldn't throwing them in the freezer be a better choice?
Incidentally, there are certainly a lot of us who love our big sockets for seating races. Aluminum race and seal setter sets are so cheap despite getting several sizes you'll probably never use that I wonder why so many settle for the Tom Joad/McGiver approach?
Jack
Old 02-24-2013, 01:39 PM   #8
Heating the races, that is something I have never heard of. If the races are heat treated at the factory to make them to a specified hardness I would think you may make them something other than what they were designed for by heating them to 450 in the oven.
This is a subject that needs an answer.
Old 02-24-2013, 01:52 PM   #9
rabbit's Avatar
Delaware
No metallurgist or even a lot of heat treat experience but I would guess that a slow heat at 450F might well temper to a hardness below the original. Anybody know?
jack
Old 02-24-2013, 02:09 PM   #10
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I'm with Jack, I'd put them in the freezer, then press them in with a bearing driver.
I can maybe see heating the hubs in an oven, but I'd stick with tator tots.
Old 02-24-2013, 02:21 PM   #11
Jared J's Avatar
Kansas
If one is around, I'll usually chuck the races in a freezer for a bit. If not, no biggie, it's a mild press fit.
Old 02-24-2013, 04:28 PM   #12
Jack, I think the tempering comes from how you cool the item.
Old 02-24-2013, 04:34 PM   #13
Tempering steel:
http://www.asminternational.org/pdf/.../tempering.pdf
Old 02-24-2013, 04:34 PM   #14
rabbit's Avatar
Delaware
Darwin, you're correct that quenching at a certain temper color is necessary to fix a certain level of hardness. A heat soak and slow cooling anneals carbon steel and leaves it dead soft. Same result as if quenched under the necessary level of hardness as it pertains to wheel bearings.
Jack
burro
Bearing and Seal Kit Deb & Chuck Commercial Posts and Products 0 06-18-2012 09:49 PM
Bearing seal question ... freddo411 Problem Solving | Owners Helping Owners 5 04-30-2012 08:27 PM
Interesting Bearing Seal Raz Towing, Hitching, Axles and Running Gear 8 05-29-2011 05:03 PM
numbers BAMA & Pachyderm Posse Forum Admin, News & Announcements 1 02-15-2007 10:01 PM
Burro Door Seal Legacy Posts Problem Solving | Owners Helping Owners 8 02-12-2003 12:39 AM
