9-pin electrical connection - Fiberglass RV
Old 01-06-2003, 10:34 AM   #1
Dena, I asked my Skip about your 9-pin connector. His gut reaction was, ''wonder why a Lite House would need NINE pins? Does it even have brakes?'' :chin
Old 01-06-2003, 10:48 AM   #2
Ray Horner's diagram from the other thread:
I pulled this topic over from the ''Lite House Trailer Manual'' thread, in case it was missed by someone who knows something about (9-pin) electrical connections to tow vehicles.
Ray Horner did post this diagram, which I'll copy here again:
<img src=http://www.fiberglassrv.com/board/uploads/3e1872a64f6b99waydiagram.jpg/>
I found something similar on a website about old Avions, but my googling brought up little else.
Dena's already inquired of the U-Haul hitch installing people in her area. (Perhaps she should try Albuquerque? :crazy-ii )
Old 01-06-2003, 12:28 PM   #3
Remind Skip that some trailers have batteries needing charging and some folks like to hook up back-up lights...
Pete and Rats who don't want back-up lights
Old 01-06-2003, 02:13 PM   #4
Pete, How would that explain 9-pins instead of 7?
Old 01-06-2003, 05:51 PM   #5
Nine pin connector
I had a nine pin connector on a unit years ago. The reason it was required was because it had separate brake and turn signal bulbs. And second it had backup lights. This required 8 pins. The last was vacant on mine. If you add up; running, brake, left turn, right turn, backup, brakes, battery, ground, and aux or spare equals nine pins.
Hope this helps.
Old 01-06-2003, 06:56 PM   #6
I was thinking of the Round7, not the Round9. Prolly the new lights so you don't need a diode block.
They also make Round6 and I believe a Round11, but the Flat4 and the Round7 are the most common:
Running, Left+brake, right+brake, elec brake, charge batty, ground and aux for the Round7 and running, LH+brake, RH+brake and ground for the Flat4.
Pete and RatLadies
Connection issues AprilL Problem Solving | Owners Helping Owners 7 07-07-2007 10:25 PM
Pig Tail Connection Legacy Posts Problem Solving | Owners Helping Owners 7 11-01-2002 06:46 PM
Trailer plus connection. Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 10-25-2002 07:31 AM
