907 KG-1980 Boler weight - Fiberglass RV
Old 08-04-2015, 05:14 PM   #1
immrbill's Avatar
The spec sheet in my 1980 Boler says gross weight is 907 KG. The conversion chart I found states 1999.6 lbs.
Does a Boler really weigh a ton
immrbill is offline   Reply With Quote
Old 08-04-2015, 06:09 PM   #2
Ian G.'s Avatar
That is gross weight, the maximum weight fully loaded. In other words you have a 2000 lb axle capacity
Old 08-04-2015, 06:22 PM   #3
immrbill's Avatar
Thanks Ian. I've never owned a trailer like this before so I appreciate the input.
Old 08-05-2015, 10:10 AM   #4
Ohio
Weight
My Scamp 16 came in at 3000# on the nose just the other day at a weight station. My grey and black water tanks were full and the fresh water was empty. My camper was loaded with everything that I usually go camping with. It was not connected to the TV when weighed.
cmartin748 is offline   Reply With Quote
Old 08-09-2015, 08:48 PM   #5
Trailer: 13' Trillium
I ran my trillium 4500 ( 15') across the scales , it was 720 kg dry weight.
caderider1 is offline   Reply With Quote
Old 08-10-2015, 05:10 AM   #6
Ohio
3000#
I think I'm still ok at 3000#, it has the 3500 lb axle. I need to recheck the tongue weight and subtract that to see what is actually on the axle.
Old 08-22-2015, 06:32 AM   #7
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
Tongue weight with home scale.
You have the procedure to weight the hand of a caravan with a home scale?
If the weight of this one can damage the home scale, I remember that there is a procedure to be followed, to adorn this problem.
I lost this procedure, you would know how can it be done?
Thank You,
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
boler, weight
Tongue weight or hitch weight Cathi Towing, Hitching, Axles and Running Gear 26 04-23-2012 11:38 PM
help - I am interested in buying a small, light weight trailer- total weight 2000 pdd pwedd Hi, I am.... 19 07-23-2011 12:50 AM
Tow weight vs vehicle weight Paula Bindrich Towing, Hitching, Axles and Running Gear 20 06-21-2007 08:16 PM
Tow Weight/Tongue Weight Legacy Posts Towing, Hitching, Axles and Running Gear 7 11-29-2002 07:49 PM
