95 Casita fridge ?? - Fiberglass RV
Old 11-30-2017, 11:38 AM   #1
Kentucky
95 Casita fridge ??
The top left hinge screws are loose on the refrigerator in my 1995 Freedom Deluxe. The screws are not accessible, so I would like to know a couple of things.
First, do the rivets in the face flange of the fridge have a backing strip on the inside so reinstallation will have a strong surface for the rivets to bite?
Second, if I drill the rivets, can I get the fridge out of the compartment far enough to tighten the hinge screws without disconnecting things at the back? I think it would have to slide out a couple of inches.
Thanks,
JIm
James Davis is offline   Reply With Quote
Old 12-01-2017, 11:29 AM   #2
Refrigerator Hinge
What make and model refrigerator do you have with the hinge problem??
Frank F
frankcfx is offline   Reply With Quote
Old 12-01-2017, 11:51 AM   #3
Kentucky
It's a Dometic, RM 2202
Thanks for asking.
Old 12-01-2017, 02:40 PM   #4
Kentucky
Just heard from Casita. It seems I can drill the rivets, then remove three screws from the back of the fridge and tilt it enough to tighten the hinge screws.
But the didn't give me any perspective about replacing the rivets when I put it back...
Old 12-03-2017, 03:24 PM   #5
Kentucky
Removed screws at back, sheared rivet heads with a sharp wood chisel, tipped fridge out at top, tightened hinge screw, replaced rivets and screws--all good again. Very easy.
I replaced the two long Philipps head screws at the back bottom with hex heads, which are much easier to install with a 1/4' drive ratchet. Recommend that change to anyone doing this procedure.
Old 12-03-2017, 04:59 PM   #6
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Glad you got it fixed and thanks for the screw head change tip, makes great sense.
Borrego Dave is online now   Reply With Quote
Old 12-03-2017, 06:18 PM   #7
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I always try to use a medium strength thread locker or even some elmers glue on the threads of any screws that have a propensity for loosening up.
Dave & Paula
casita, fridge
Replacing a stand-up absorption fridge with a chest-type compression fridge TwoplusLu Modifications, Alterations and Updates 14 08-30-2017 05:46 AM
Fridge - Freezer is great, fridge is too warm? TheRedDawn Problem Solving | Owners Helping Owners 14 07-28-2016 11:12 AM
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
3-Way Fridge vs AC DC Fridge? Krista Modifications, Alterations and Updates 44 04-14-2016 06:34 PM
Casita 16 fridge size Mike Magee Care and Feeding of Molded Fiberglass Trailers 2 12-19-2010 03:04 PM
