A few power related questions (Scamp 13) - Fiberglass RV
Old 10-15-2017, 06:53 AM   #1
Quebec
Subject is a 2010 Scamp 13.
Is there any reason the power inverter was not plugged into the fuse panel when I got this trailer? Why would it be unplugged? Just curious if there is any reason I can not leave it plugged in 24/7.
Second, When hooked up to house power and the power inverter is plugged in, I notice that a 12v charge is sent to my battery Is there any overcharge protection in this circuit if I left the house power hooked up with the battery installed for a few months?
Thanks all.
Luxus Panzer is offline   Reply With Quote
Old 10-15-2017, 07:29 AM   #2
Ed Harris's Avatar
Thanks all.
First of all I imagine you mean to say Power Converter not Inverter which does the exact opposite thing?
No Scamp that I am aware of will make 120vac power from a 12vdc Battery which is what an Inverter does.
The Converter makes 12vdc from the 120vac Shore Power Input and also usually charges the House Battery in your Scamp.
Most factory Converter/Chargers do not do a great job of charging the battery and so this might be why yours is unplugged and the previous owner may have tried his hand at charging as needed instead of leaving the charger unattended to potentially just cook out the battery?
Many feel a converter with the "Charge Wizard" module is a decent charger for house batteries that is built in to some converters but I have no experience with them and can not say.
The Wizard provides a more modern multi-stage charge while also cycling its charge to avoid overcharging and battery destruction like most modern outboard battery chargers also do.
Most just leave the converter connected all the time and replace the battery when needed or when it is discovered to be dead at the worst possible time.
Ed Harris is online now   Reply With Quote
Old 10-15-2017, 07:37 AM   #3
A design flaw.. the plug for the converter has been known to fall out from all the vibration while driving. Just find a way to secure it (such as I did in below photo).
As for overcharging.. we need the make and model of your converter to answer that. Scamp almost always puts the cheapest (reasonable) converter in and it might well overcharge. If your converter is a Progressive Dynamics model that can take the optional "Charge Wizard" module, that will improve the charging profile a lot. But some converters have that already built in, other makes dont use it, some have different charging algorithms.. so need to know which converter you have.
Its a little hard to see in this photo but two wire ties are used to hold the plug in.
Old 10-15-2017, 08:23 AM   #4
overcharging
most people don't understand charger concepts to a battery no matter what you are using say 2amps you will get to the point that battery will no longer have it electroleits in it. As Ed says cooked away.
hook it back up and see what happens cant hurt much.
good luck
bob
Old 10-15-2017, 10:10 AM   #5
Agree. The plug probably just popped out.
My 2008 Scamp converter does not have smart charging circuitry, so I would not leave it plugged in and charging for long periods in storage. Since I never plug in when camping anyway, and since I do not have access to an outlet where the trailer is stored, I elected to stick with the "dumb" Scamp converter and remove the battery for storage, connected to a modern smart charger.
Old 10-16-2017, 06:29 AM   #6
Quebec
I will grab some pics later...its raining right now
Old 10-16-2017, 11:45 AM   #7
Converter/Battery
We have a 2006 Scamp 16' and I have kept it plugged in (and charging) all the time we're home since we bought it new. The converter keeps the battery at 13.1 volts, high enough to recharge it slowly but not so high as to boil off electrolyte. I have replaced the battery twice, once when it froze because it discharged when the fuse had become dislodged and once because I thought I should after 6 years. This works for me.
Lynn
Old 10-16-2017, 01:44 PM   #8
this is a good read.....and rather short considering all the bases it covers....
https://www.emarineinc.com/Batteries-Maintenance-101
(pics of my batteries and a supporting opinion)
Old 10-17-2017, 08:35 AM   #9
Quebec
here are some pics of my converter.
It is a Intel power 9100 Model PD9130
There is documentation (see pic) that states it will not overcharge, yet I find mention of add on devices (TCMS interface) to stop overcharging...soo confusing.
IMG_20171016_181534 by Z R, on Flickr
IMG_20171016_181316 by Z R, on Flickr
IMG_20171016_181525 by Z R, on Flickr
2017-10-16_10-31-59 by Z R, on Flickr
Old 10-17-2017, 08:47 AM   #10
battery charging
after awhile of this charging might want to check the water in your battery it will boil out after awhile regardless. maybe after a few years it doesn't matter!
bob
Old 10-17-2017, 10:38 AM   #11
Quebec
bob
Sound advice.
Under constant charge, will the water in the batt freeze?
Old 10-17-2017, 10:44 AM   #12
battery freezing
a fully charged battery may freeze say in 50below temps but I have never lived in such an area I wouldn't be surprised that they don't take their battery out!
I know I would! I have had batteries freeze up due to no charge.
bob
Old 10-17-2017, 02:58 PM   #13
"Second, When hooked up to house power and the power CONVERTER is plugged in, I notice that a 12v charge is sent to my battery Is there any overcharge protection in this circuit if I left the house power hooked up with the battery installed for a few months?"
13.6 is not overcharging, (read link I posted earlier) and your documentation states that after the battery is "fully charged" it steps down to a maintenance charge (likely 13.1 or 3)
nothing wrong with leaving converter/charger plugged in indefinitely if it's operating according to specs....just check the water/acid level once a month and add using distilled water.
As a "for instance" my two six volt batteries, together, go through 1L of distilled water every month or two (that's adding half an inch to an inch of water, in height, in the individual battery cells)
and while I'm at it....when I do this check, before I add water, I test every cell with a hydrometer to see if I'm developing a weak cell (they should all read about the same)....a weak cell will make the whole battery weak (less power available for use)
If this trailer is "new to you" and you have suspicions about your electrical system, first start by ascertaining that your battery is up to snuff....your fully charged battery "at rest" should read 12.6+ on a voltmeter... then perform a hydrometer test on every cell (1.265 or more)...
Old 10-18-2017, 02:20 PM   #14
Quebec
Thanks. I have filled this batt with distilled water and have it on a intelligent charger @ 2A. Hopefully this will de-sulfate this "unknown" battery with a production date of 2010.
As a backup I have a 110AH 12v deep cycle battery that is 2 years old and has always been properly maintained by myself to fall back on (it is for my boat motor)
Multiple Electrical Questions (related?) fieldphoto Electrical | Charging, Systems, Solar and Generators 25 11-29-2016 05:19 PM
A few questions ... okay, more like a lot of questions! shelley w Problem Solving | Owners Helping Owners 6 07-04-2012 10:25 PM
Solar related Q: flex power mat? jen b Care and Feeding of Molded Fiberglass Trailers 27 04-28-2011 04:30 PM
Upgrading an ancient power converter - a few questions Angelo F. Problem Solving | Owners Helping Owners 10 08-31-2007 04:16 PM
