A few questions: - Fiberglass RV
Old 05-15-2014, 05:06 PM   #1
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
A few questions:
1)I'm about to close the heater back in, I know there was insulation around it... But I forget where: covering the holes? Around whole things? Don't cover holes?
Name:	ImageUploadedByFiberglass RV1400194877.839436.jpg
2) is this an inline filter cup of some sort? Because, see, the lid breaks when you run into it say 7 times.
Where can I get a new one?
Name:	ImageUploadedByFiberglass RV1400194991.447450.jpg
3) the undersink hose fitting for the hand pump was very brittle and snapped off when I pushed new hose on. There is a valve inside that I've never dealt with. Is this a normal box store piece or do I need to order it?
Name:	ImageUploadedByFiberglass RV1400195183.102854.jpg
summer scamp is offline   Reply With Quote
Old 05-15-2014, 07:59 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
1 - I wouldn't insulate anything, none of my furnaces have ever had it in 30 years.
2 - Any RV store has an inline filter - move it if you need to make a new one fit.
3 - Looks like a standard pipe thread - big box store and get a coupling, then put in a new pipe fitting for the hose.
Charlie Y
Charlie Y
Old 05-15-2014, 08:21 PM   #3
Filter
Charlie Y
2) My filter broke in the same fashion on my Scamp > I discovered the break when I turned on the pump and found water was running out on the ground under the trailer. New filter was about $5 at local RV store . I added some hose on the pump side of the filter and moved the filter / screen to a safer location.
Old 05-15-2014, 11:33 PM   #4
Kevin, there is no insulation on or near my Scamps furnace. You might want to down load the manual from the documents centre here to see if there are any install instructions.
Old 05-17-2014, 07:50 AM   #5
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
All sounds great. Thanks.
Now I have a dometic vent brand new from scamp for my AC access panel and it didn't come with any hardware to attach it in the hole I need to cut...
The refrigerator cover has metal clips that hold the cover to the fiberglass with tension from a bolt going through vent cover then through the metal clipClick image for larger version
Name:	ImageUploadedByFiberglass RV1400334602.591361.jpg
Was scamp suppose to send those to me with the cover or am I fashioning them myself???
Old 05-17-2014, 08:14 AM   #6
Number One Tip (Albeit after the fact) Always take pics before and as you take things apart.
Old 05-17-2014, 08:40 AM   #7
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
This is the pic of the fridge vent clips as reference... I haven't cut hole for AC yet because I'm curious if they should have given me these clips, if I can buy them, or I have to make them.
Old 05-17-2014, 07:32 PM   #8
All the vents installed by Scamp on my trailer are riveted on. Put some butyl tape under the edges of the vent before riveting.
A few questions ... okay, more like a lot of questions! shelley w Problem Solving | Owners Helping Owners 6 07-04-2012 10:25 PM
New Guy With a Few Questions sean m Problem Solving | Owners Helping Owners 18 11-04-2009 01:20 PM
Upgrading an ancient power converter - a few questions Angelo F. Problem Solving | Owners Helping Owners 10 08-31-2007 04:16 PM
A few questions Lisa F General Chat 5 04-06-2006 03:10 PM
