A Frame tongue jack - Fiberglass RV
Old 11-23-2007, 02:09 PM   #1
Timmy G's Avatar
Trailer: TM14 Surfside
I need a new one for my Surf Side ... I want one that has the lowest aspect possible (so that it doesn't interfere with the back door of my Highlander), as well as good quality. Anyone have any experience buying these?
Merci,
Tim
Timmy G is offline   Reply With Quote
Old 11-23-2007, 05:33 PM   #2
Trailer: 2005 13 ft Trillium Outback
I like the Ultra fab 3502 elect jack. It doesn't have that low a profile, but can hanle 3500 lbs. I chose to get a refurbished one from EBay. Seller Campinggurl (100% positive feedback) has an inside conneciton with the factory and sells the remanufactured units on EBay. Starting bid is 109.00 and buy it now is 129.00. Comes with one year warranty. I broke mine and they are replacing it anyway. If you are like me and don't want to bid up the price. Just keep bidding the minimum and you will eventually get one for 109.00. Only took me a week before the other bidders bought theirs and one was left for me.
Campinggurl on Ebay
Curt
2005 Trillium Outback w/ 30" tongue extension
1989 Award 730, 30'
2003 PT Cruiser
1998 K2500 Chevy Silverado 6.5 Turbo Diesel, 4X4, ext cab, short bed
Curtis F. is offline   Reply With Quote
Old 11-24-2007, 06:57 PM   #3
Pete Dumbleton's Avatar
If you get the kind that clamps to the side of the tongue, it can be mounted further back and folds out of the way when not in use.
Old 11-24-2007, 08:30 PM   #4
With a top crank you can't get very far back or the crank runs into the Propane tank. When my 13' was delivered that was the case. It had to be cut off and reattached as far forward as possible. A side winder would be different matter.
Old 11-24-2007, 09:32 PM   #5
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
I use a weld on swing away jack. It is totally out of the way.
It looks like this one. http://www.drawtite.com/dt53525.html
Old 11-25-2007, 10:31 AM   #6
Brian B-P's Avatar
My Boler has a 16" top-of-frame and top-to-ball height, which I'm guessing is at least as high as a Surfside. My tug is a Sienna, with a lower floor than a Highlander, and a taller hatch, both of which suggest to me that the bottom of the hatch would swing lower than that of a Highlander. My jack is mounted through the hole in the back of the coupler, as far forward as possible. The trailer rides level.
The net result is that I should have hatch-to-jack clearance problems, and indeed I must have the handle of my front-wind jack in the down position to clear.... but it clears. I would be surprised if it's necessary to go to the trouble of changing the jack mounting to clear the Highlander's hatch.
If the rear of the tow vehicle is pushed down too much by the tongue weight, that will increase hatch-to-jack clearance problems. I use air bags in the van's rear suspension, which essentially eliminates this potential problem.
My jack is presumably the 1979 original, and other than the plastic of the handle grip coming apart (not completely yet) and the foot being missing (it's just a tube end now, distorted by being dragged at some point by a previous owner) it is working fine. I believe that it's an Atwood, like the coupler.
Trailer tongue power jack The Hobo General Chat 9 02-24-2009 01:52 AM
Tongue Jack Replacement? Parker Buckley Problem Solving | Owners Helping Owners 8 12-03-2007 08:06 PM
Tongue Jack Parker Buckley Problem Solving | Owners Helping Owners 16 11-14-2007 08:06 PM
Electric Tongue Jack Donna D. Problem Solving | Owners Helping Owners 23 02-15-2006 06:26 PM
Power tongue jack Legacy Posts Modifications, Alterations and Updates 20 07-20-2003 02:42 PM
