A leak! - Fiberglass RV
Old 04-17-2007, 02:52 PM   #1
Rarebird's Avatar
Trailer: Trillium 4500
Well, I thought all was well after the nor'easter this weekend, until I checked on the Scamp. It leaked! The front cushions are wet...it didn't seem to come in from the window, but just below. It did appear wet at, and below, the seam that runs around the Scamp. It's metal on the outside, and just a seam on the inside.
So, my question is, can I just caulk around the metal band? Using what?
Thanks!
Marjie
Rarebird is offline   Reply With Quote
Old 04-17-2007, 02:57 PM   #2
Chester Taje's Avatar
I have seen a number of Boler trailers with some sort of caulking around the belly band.I also noticed that it was kinda flexable.Sorry but i did not ask any of them as to what they used.If it was me i would try some kind of window caulking.
Hopefully others will jump in with there ideas.
Old 04-17-2007, 03:50 PM   #3
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: SSSHHH!!! Don't tell everyone you have an indoor pool or they'll all want one... The leak we had in the front of our '77 Boler was from the curtain rod bracket pop rivets. Also the vent window behind the stove bottom right corner leaks and the water ends up in the front left stowage bin...The window in the door also leaks... Silicone sealer doesn't usually work well or last long. I am replacing the pop rivets with S/S bolts with nylon washers against the fiberglass. There is also a weather seal washer that has rubber bonded to the metal but I haven't seen them. Alf S. North shore of Lake Erie
Old 04-17-2007, 06:32 PM   #4
There's a very good chance it's NOT the belly band. The two halves of the fiberglass shell are bounded together right there (on the inside of the trailer), the belly band is merely a decorative trim. It's probably the closest window...or a vent. Then, I'd check the rivets in the area too. Alf is changing the rivets over in his trailer to SS bolts...but it's not the rivet that may leak....it's the hole!
If it's the front window (or rear) and it's a solid plexiglass window...check the rubber gasket where it joins together. The one and only leak I've ever had was right there. I used some black windshield goo to fill the area, and so far (four years) no return leak.
Old 04-17-2007, 06:33 PM   #5
Try here, ALF., or you might find something in Ontario.
McMaster-Carr
Bonded Sealing Washers
Morgan is offline   Reply With Quote
Old 04-17-2007, 07:08 PM   #6
Alf S.'s Avatar
Hi: I was in our trailer one day during a downpour to check for leaks and I could have used some help from a Little Dutch Boy!!! I now have two rolls of Buytl tape and hundreds of S/S fasteners/washers to fill the holes. I remember telling a guy one time that if the car didn't have a sun roof it wouldn't leak Alf S. North shore of Lake Erie
Old 04-18-2007, 06:04 AM   #7
Suz
Suz's Avatar
I always start with the easiest fix first. Try cleaning out the weep holes on your windows. They can get clogged over time. Condensation and moisture will cause it to overflow into the inside if they are clogged. A good length of strong weed whacker cord run all the way around will usually do the trick.
Suz is offline   Reply With Quote
Old 04-18-2007, 10:45 AM   #8
Rarebird's Avatar
First, thank you to everyone who replied to my question, I really appreciate all the help!
Now...OK, I understand it all, except, what exactly is a weep hole? And where do I find them?
Marjie
Old 04-18-2007, 11:03 AM   #9
Marjie
They're in the outside track of the windows, little holes in the bottom of the track. Run the weed wacker cord though them. It's also a good time to take an old toothbrush to the entire track to get dirt/moss, etc. out of the track so the window will slide smoothly.
Old 04-18-2007, 01:08 PM   #10
Trailer: Fiber Stream
Talking
The front cushions are wet...it didn't seem to come in from the window, [b]but just below.
I thought weep holes were on openable windows only. Definately on sliders, not sure of crank-outs.
Isn't the Front Window on a Scamp solid curved plexiglass? I didn't think that it would have weep holes.
I had a leaky front on my Fiber Stream, and endured wet cushions until I found [b]EVERY POSSIBLE penetration or gap and got them all sealed up. I [b]do have an openable slider across the front of my Fiber Stream, but I [b]do not have a belly band.
Rock Guard Open________/Rock Guard Closed
Possible Penetrations and Gaps:
  1. Window Frame (mine is metal & sealed with Butyl Tape)
  2. Window Glass Gasket (See White Caulk filling gaps in Black Rubber)
  3. Weep Holes (Black Plastic Covers at lower outside corners snap over openings to direct draining water down, and Prevent Rain from comming in)
  4. Rock Guard Mounts (My guard mounts to the frame, but yours may mount separately to the shell) A Rock Guard will NOT prevent rain from getting on and through a leaky window
  5. Rivit or Screw Fasteners through the Shell (I have 6 over the window for the upper bunk/shelf, 2 at the upper side corners for the curtain rod brackets, and 4 below the window that used to be where the sewer hose storage was)
Old 04-18-2007, 01:25 PM   #11
I've seen front windows on a couple of Scamp's that had actually opening windows. Front bath models come to mind.
Old 04-18-2007, 01:31 PM   #12
Talking
So, my question is, can I just caulk around the metal band? [b]Using what?
I have also caulked around the Roof Vent, along the Awning Rail, and around each Baggage Hatch Frame. I use C-10 Self-Leveling Sealant
Old 04-18-2007, 01:44 PM   #13
Alf S.'s Avatar
Hi: The only weep holes I have are the ones on either side of my nose!!! They only cause me trouble when things don't go "MY WAY"!!! Alf S. North shore of Lake Erie
Old 04-18-2007, 02:16 PM   #14
lwehrly's Avatar
Trailer: Honey
I haven't found weep holes in my trailer windows, but I have a problem with the ones on my house getting clogged up. I am using the weed wacker line suggestion right away. It is amazing how much I learn on this site!
lwehrly is offline   Reply With Quote
GAS LEAK Keith & Beverly General Chat 3 09-01-2009 02:57 PM
Leak! Help! BOBSMITH Problem Solving | Owners Helping Owners 7 10-02-2008 11:38 PM
Need help with leak Brenda Ferrell Problem Solving | Owners Helping Owners 7 01-01-2008 04:20 PM
A/C leak? Linda&Dale Problem Solving | Owners Helping Owners 7 03-11-2007 04:50 PM
Leak Legacy Posts Problem Solving | Owners Helping Owners 5 06-27-2003 03:14 PM
