A Weak Glue - Fiberglass RV
Old 09-21-2019, 02:55 PM   #1
Trailer: Roamer TC
A Weak Glue
Looking for a good way to weakly glue wood to gelcoat fiberglass interior wall.
I am mounting a board as a sort of bed rail (to hide the side of the bed) and using two bolts into the FG, but want more strength as I will be sliding across the board to access the bed. However, I do want the option down the road to remove it all with not much more than the 4 holes left behind.
Anyone used a weak glue that was good enough for the job, but not so good that it could not be removed?
I was thinking to use some cheap caulk or lap sealant. Just enough stick that it gives the support.
I have approx a 2x2 wood that gets attached to the gelcoat and the long bed board screws into that. The 2x2 is 5 inches tall and is what is getting bolted and glued.
Roamer is offline   Reply With Quote
Old 09-21-2019, 08:41 PM   #2
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
I suggest either contact cement, or 3M body molding adhesive. If you can't just pull the piece off, you can "saw" along the glue line with dental floss to remove stuff. Any residue can be removed easily with an eraser wheel. This is used on auto paint, and things can be removed with mo evidence they were there, such as removing name badges and model numbers from cars.
Raspy is online now   Reply With Quote
Old 09-21-2019, 11:51 PM   #3
Trailer: Trails West
double sided carpet tape should work just fine for this job.
Old 11-02-2019, 12:30 PM   #4
Trailer: Roamer TC
I don't have a pic posted yet. I ended up using caulk since I had that on hand. The bolts worked alone pretty well and the fiberglass was thick enough for a god anchor, so the caulk kept things stable and from wiggling. So far so good, and it can be undone easily if ever needed - no residue
What glue is the best to glue the fabric on the sealing. Falicea Problem Solving | Owners Helping Owners 11 10-31-2017 09:22 PM
How to troubleshoot Scamp 16 12V lights, pump (weak)? Rebecca3 Problem Solving | Owners Helping Owners 14 07-16-2016 01:39 PM
Trailer Brake Weak on One Side of Boler Michael Collins Problem Solving | Owners Helping Owners 3 05-27-2010 11:33 AM
Adhesive to glue foam cushions together? Legacy Posts Problem Solving | Owners Helping Owners 4 03-12-2003 09:37 PM
