Abandoning exterior rivet/screw holes - Fiberglass RV
Old 11-16-2012, 04:52 PM   #1
Trailer: Casita 17'
In the back corner of our Casita where we sleep, there are 3 small metal brackets (for a small TV wood shelf for I guess). Each bracket is secured through the exterior wall with two pop rivets. We've never needed to use the brackets. However, they're a problem since the brackets just above my wife's head during sleep times. Consequently, they're semi-dangerous. I want to eliminate them.
If I drill out the rivets, how do I seal the holes? Is there a cosmetic application on the exterior surface or just live with the visual of 6 previous holes? Thank you for any response(s).
yolofitz is offline   Reply With Quote
Old 11-16-2012, 06:13 PM   #2
I guess the easiest thing to do would be to drill out the rivets and remove the brackets, then install new rivets in the existing holes through the bottom half of the "snap caps" but attaching nothing.
Add a dab of caulk and cover it with the upper half of the snap caps.
Old 11-16-2012, 06:17 PM   #3
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Everything Frederick said, except perhaps:
Instead of putting rivets back in, you might just buy nylon hole plugs- they can be pushed on with a dab of caulk applied beforehand, will fit snugly and won't leak. Available in various sizes at any hardware store...
Francesca
Old 11-16-2012, 06:21 PM   #4
Thomas G.'s Avatar
Some good suggestions here.
Old 11-16-2012, 06:58 PM   #5
Trailer: Casita 17'
Thank you very much. All of your suggestions are workable. I'm going to concentrate on the epoxy with small amount of white paint/get(?). Again, thanks.
Screw holes? pindraak Problem Solving | Owners Helping Owners 72 05-23-2022 12:19 PM
Stripped Screw Holes Quint362 Problem Solving | Owners Helping Owners 15 03-12-2012 08:19 PM
Off-kilter window rivet holes Amy M Problem Solving | Owners Helping Owners 10 02-04-2010 08:54 PM
plugging rivet holes steve J Care and Feeding of Molded Fiberglass Trailers 13 07-06-2009 06:38 PM
Replacing white plastic rivet/screw covers WayneJ Care and Feeding of Molded Fiberglass Trailers 8 03-06-2006 03:47 PM
