? about our new Scamp - Fiberglass RV
Old 07-20-2013, 06:47 PM   #1
Trailer: 2015 Scamp 16' deluxe 2008 FJ Cruiser
We brought our new Scamp 16 front bath side dinette home last week and have been trying everything out. First thing how long does the frig take to cool down on electric its been two hours and its only gone down 2 deg. Worked faster on propane. Second thing. Why would you put the thermostat at the foot of the bed where your feet hit it and it gets covered by blankets? I moved it. Third how do you take a shower without using up all the water in your tank? We had a extra tank installed thank goodness wife and I toke showers and used about 8 gallons out of 24 possible. I guess we have to work on that. I already mounted the fence post cover underneath for the sewer hose, made a cutting board cover for the stove, installed a microwave, and fixed the shower drain that fell off underneath, and new curtains. All and all we love it. Ken & Pat
Ken in Pa is offline   Reply With Quote
Old 07-20-2013, 06:53 PM   #2
cpaharley2008's Avatar
The refer should cool down in about 4-6 hours on a/c, make sure the unit is level. To conserve water you take "Navy" showers where you fill the sink and bathe with that water via wash cloth or sponge, you then shower off the soapy water quickly. No more than 2-3 gallons
Jim
Never in doubt, often wrong
cpaharley2008 is online now   Reply With Quote
Old 07-20-2013, 06:59 PM   #3
Jim you were right the FJ handled the scamp great with no problems on the way home from Backus. Only thing 21 mpg going 13 coming back with a head wind and rain. Also didn't need the airbags waste of $ never put in more than 5 lb.
Ken
Old 07-20-2013, 07:05 PM   #4
carlkeigley's Avatar
NE Oklahoma
In our unit, we were allowed one gallon for a shower.
Get wet with cold water. Lather up, rinse off.
Towel off what was left.
Old 07-20-2013, 07:07 PM   #5
papa-t's Avatar
Glade Valley, North Carolina
Congrats on the new unit Ken.
ďI have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!Ē óJohn Wayne
papa-t is offline   Reply With Quote
Old 07-20-2013, 07:12 PM   #6
Ken
I never put in more than 5 myself, as long as it keeps it level. Do you have a w/d set up? I wondering if the FJ can handle the new 21'?
Jim
Old 07-21-2013, 06:52 AM   #7
We do not have the w/d or the sway systems. Our trailer even has two propane bottles and still rode nice and level. We are real happy with the FJ. Jim are you a member of the FJ forum they can help with questions about the 21'. There are people on there pulling that size. Thanks for all your help.
Ken
Old 07-21-2013, 06:54 AM   #8
Yes, I'm there also, have't found anyone else with the new 21' Escape. I'm probably going to get a w/d for the FJ, it squats with the 19'. My air bags are on my Ram. I'd like to put them on the FJ but it involves a lot more labor.
You guys aver go to Burnt Cabins? Here is info http://agmap.psu.edu/Businesses/index.cfm?fid=3607
Jim
Old 07-21-2013, 07:32 AM   #9
Never been to Burnt Cabins I hope to some day. On the airbags not much labor at all. I jacked up the FJ and removed the tire. Stepped on the airbag to get all the air out lubed them up with soap and pushed them in. Hooked up the hoses and done. No wrenching involved. Found that tip on the FJ forum.
Ken
Old 07-21-2013, 08:08 AM   #10
I see, the newer ones, like mine you have to remove the spring as there is a rubber bumper inside, real pia. Anyway, glad it worked out. By the way, I added led to the FJ's mirror lights and a set of auxiliary lights, discussed here Night time towing
Now back to your regularly broadcasts.
Jim
Old 07-21-2013, 11:52 AM   #11
Brian B-P's Avatar
The reason that installation of Firestone airbags in the FJ Cruiser involves significant labour is that the bump stop must be cut off to form a suitable upper seat for the bag, as described in the Coil-Rite kit 4135 installation instructions.
That's the normal procedure for vehicles which have nothing inside the coil to be removed, and nothing extra to be installed (some vehicles require spacers or seats). What did the FJ forum say to do about the bump stop - or is it missing on your FJ, Ken?
Old 07-21-2013, 02:39 PM   #12
Yes I forgot. The bump stops were shortened in a minute with a sawzall soapy water for lube and a long blade. A spacer was also added to the inside bottom of the spring by just pushing it in. The hardest part was getting the tires off and on.
Ken
Old 07-21-2013, 02:41 PM   #13
great idea on the sawmill, I'll have to remember that if I ever change my mind about bags for the FJ.
Jim
Old 07-21-2013, 08:57 PM   #14
Brian B-P's Avatar
Yes I forgot. The bump stops were shortened in a minute with a sawzall soapy water for lube and a long blade. A spacer was also added to the inside bottom of the spring by just pushing it in...
Thanks Ken, that makes more sense. I can see why Firestone would not instruct installers to use a saw between the coil turns - and I would be very careful not to nick the wire - but it's good to know everything can be done through the coil.
