Adapter help please - Fiberglass RV
Old 03-11-2013, 07:22 PM   #1
Trailer: Chez Nous - a 2011 Scamp 16'
Adapter help please
Can someone point out to me (at say Amazon) the type of adapter I need to plug my Scamp into my normal home electric socket. Looks like it will be some HUGE type of adapter for that monstrous Scamp cord plug.
Sharon
SharonM is offline   Reply With Quote
Old 03-11-2013, 08:02 PM   #2
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Sounds like you've got a 30-amp cord- is that right? If so, you don't need anything more complicated than this three-dollar part.
Do keep in mind that you'll only be able to draw the standard 15amps from the outlet. Don't try the microwave, air conditioner, fridge and hair dryer all at the same time!
Francesca
Old 03-11-2013, 08:12 PM   #3
Thank you thank you. And if the house doesn't blow up, hugs too.
Sharon
Old 03-11-2013, 08:14 PM   #4
PS -- I've got whatever that big black cord is that's attached and standard on a Scamp 16'.
Old 03-11-2013, 08:19 PM   #5
-- Wow, $3 plug and $10 shipping at PPL? Unreal. Let me check Amazon where I can use prime for free shipping. But ty for showing me what I need!!!
S.
Old 03-11-2013, 08:26 PM   #6
Bryan L.'s Avatar
Trailer: 1991 Scamp 16 ft
This is what you need at Amazon.
"The babbling that I brook." - Pink Floyd
1991 Scamp 16'
Bryan L. is offline   Reply With Quote
Old 03-11-2013, 08:28 PM   #7
If you have an RV part dealer close by... EVEN WalMart.... don't pay shipping!
Old 03-11-2013, 08:31 PM   #8
Thanks.
Old 03-11-2013, 08:34 PM   #9
Its a 30 AMP and the recommendation made will work just fine to connect it to the house power. You should be able to pick one up at any Camping World or local RV shop.
Old 03-11-2013, 08:36 PM   #10
One more question ... a while back I got a Progressive Industries SSP30 Smart Surge. Would it be useful in any way for me to use this surge protector gizmo while plugged in at home?
Also, I was just reading to be VERY CAREFUL not to turn much on in the Scamp (maybe not the A/C) because of overheating problems plugging in at home. Is this true? Same for microwave? I know now not to turn them all on at same time, but how about individually only?
Sharon
Old 03-11-2013, 08:43 PM   #11
Bryan L.'s Avatar
I've run the AC in mine before without any problems and a few lights. Never been a problem for me personally.
I will gladly pay a couple bucks shipping to save me 40 minutes out of my day going to Walmart along with a couple of bucks in gas to get there!
1991 Scamp 16'
Old 03-11-2013, 08:44 PM   #12
Using the surge protector can never hurt. I dont have an AC or Microwave so have never used either when plugged into only 110 power but I have used my TV & DVD and toaster oven & other electronics many times without a problem.
Old 03-11-2013, 10:04 PM   #13
Robin G's Avatar
Trailer: 2007 Casita
Sharon
It's about amps! The problem would be that the household plug won't provided enough amps to run the AC.... But as Brian said, I too have turned it on. I don't run it though, because I don't want to put undo stress on my AC for not having enough power provided.
Personally I don't use a mircrowave even at home so blowing up a micro wouldnt' bother me , but check how many amps your micro uses and make the decision for your self.
I take it you don't care for Walmart Bryan! I personally would drive across town to avoid walking into a Walmart........
Old 03-12-2013, 01:18 AM   #14
Sharon
The surge protector won't hurt anything, but unless you've got sensitive electronics aboard the trailer I wouldn't bother with it when at home. Use in RV's is often recommended due to unpredictable wiring at RV parks, some of which have whatchamighcall jerry-rigged systems.
There won't be any overheating problems because the 15amp circuit you're plugging into will just trip if you try to draw power beyond that limit. That's what the breaker's there for!
Francesca
Trillium 5500 will be towed by flat-4 truck...which adapter do I need? Laurie Towing, Hitching, Axles and Running Gear 24 06-06-2011 10:38 PM
need adapter 13 scamp BarryS Towing, Hitching, Axles and Running Gear 4 08-17-2009 03:40 PM
Four-prong flat to seven round wiring adapter Adam S. Classified Archives 0 07-03-2009 05:05 PM
Wiring Adapter? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 06-20-2003 06:21 PM
Power Caster Adapter Legacy Posts Modifications, Alterations and Updates 2 02-05-2003 12:15 AM
» Trailer Showcase
TBD
Andi
BIGFOOT
OKE
