Add A Awning Or Not - Fiberglass RV
Old 09-24-2011, 10:37 PM   #1
Troy Hawkins's Avatar
Trailer: Burro 13'
Kentucky
Add A Awning Or Not
Hi, As anyone ever put a pole & rope awning to a Burro trailers? Do you think the Fiberglass will hold A section of awning rail?
Troy
Troy Hawkins is offline   Reply With Quote
Old 09-24-2011, 10:53 PM   #2
Trailer: Fiber Stream
I have seen several Burros that have awnings, the fiberglass will take an awning rail riveted on fine. A simple pole & rope awning would be the easiest to make, and I like their classic look. As it has to be removed for travel, it may pose the least stress to the body?
Welcome to FiberglassRV Troy
Old 09-25-2011, 09:54 AM   #3
Trailer: Burro 13'
Kentucky
Thanks frederick.
Old 09-25-2011, 11:45 AM   #4
Trailer: 1987 scamp 5th wheel
When putting up a awning rail you should use molly rivits. They spread out like a star and hold more. Put molly rivet in the search page for more info and pics.
garycoughlin is offline   Reply With Quote
Old 09-25-2011, 02:33 PM   #5
Originally Posted by garycoughlin View Post
When putting up a awning rail you should use molly rivets. They spread out like a star and hold more.
I have those fastening my awning rail up. I found this during a search for "Molly Rivets" :
Gesipa - GAMD66ATF BLK - Tri-fold Rivets
Old 09-25-2011, 08:14 PM   #6
Pam Garlow's Avatar
Trailer: U-Haul 1985
I have a Uhaul (same config as the burro with double shell). I installed the rail with butyl tape under it, and 'blind' rivets through the outside shell (does not go through the inner shell). Installed quickly and simply. Using the combination of tape and rivets makes it very secure.
Old 09-26-2011, 09:32 AM   #7
Trailer: Burro 13'
Kentucky
Thanks all, I will get the Molly Rivits asp also Looking for the right fabric you see I got Mark Shaffer's burro-stream and need to keep it looking as good as when I got it.
awning, burro
Awning Add-a-Rooms Lisa H. Problem Solving | Owners Helping Owners 2 06-06-2010 05:01 PM
Surfside awning and or add a room ? ericmarlo Classified Archives 0 07-05-2007 10:54 PM
13' Boler Awning or add-a-room Danielle Lee Classified Archives 0 07-01-2007 12:08 AM
Awning/Add-a-Room Fix Brenda Novakovski Problem Solving | Owners Helping Owners 1 05-08-2007 02:54 AM
Installing an awning & add-a-room Legacy Posts Problem Solving | Owners Helping Owners 53 11-18-2002 02:28 PM
