Adding rear jacks - Page 4 - Fiberglass RV
Old 05-11-2013, 05:58 PM   #43
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
I had the Atwoods welded to the back bumper (where I used to put the other jacks.) They'll work great. My friend who did the work also made a spare tire carrier for me and fixed the propane tank holder.
I'll get some blocks of wood for the sand in my driveway in Washington but ordinarily I think the stands will be fine on their own. (Most of our campsites are pavement or gravel.)
Old 05-11-2013, 06:53 PM   #44
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Hey, Bobbie!
I got an old white plastic cutting board at a thrift store and cut it in half to form "pads" for my Atwoods...worked great for sand or hot asphalt, and didn't take up much room in the trailer.
I still have the pads, though I busted the jacks last year- guess they'll be useful if/when I get the new ones on...
Francesca
Old 05-11-2013, 07:20 PM   #45
I have a package of leveling blocks I use under the my rear jacks & tongue jack if the ground is soft - they come in handy for leveling the trailer as well . Use to use wood blocks until the trailer took a trip on its own once due to the wood being wet and apparently very slippery. Only took someone stepping out of the trailer & pushing off on the trial to get it to slip off the blocks.
The bar I have for use on my jacks has no handle. Just a straight bar.
Old 05-11-2013, 08:48 PM   #46
Trailer: none
I never use that leveling bar....I just get trailer where I want it (level) , drop jacks onto wood ect, drop tongue, snug rear jacks down with foot,raise tongue
Hambone is offline   Reply With Quote
Old 05-11-2013, 09:13 PM   #47
Francesca, how did you break the jacks? Forget to raise them?? That's a great idea, though, and if I didn't throw it out I have a plastic cutting board I accidentally melted on the stove.
Old 05-11-2013, 09:18 PM   #48
That's probably what I will do, too.
I have a indented plastic pad thingy for the wheel jack. I'll see what the Atwoods need. Maybe a couple of the free promotional Frisbees they are always giving away at dog things will work. (My dogs won't chase Frisbees.)
I also got the new breakaway cables on- bought them six years ago and couldn't figure out where to attach them so have been using the old chains. What I forgot to do.
Old 05-12-2013, 09:50 AM   #49
Don'n'Deb's Avatar
Name: Donald & Debra
Trailer: Compact Jr 'RV There Yet'
For the jacks on the 'old' tent trailer, I used an old, heavy screwdriver (flea market find)
RV There yet??
Don'n'Deb is offline   Reply With Quote
Old 05-12-2013, 09:53 AM   #50
Oh, great idea, I have a ton of weird drivers (bought a bag at a yardsale once) and will have something that should work great.
Old 05-12-2013, 11:35 AM   #51
Don'n'Deb's Avatar
The one I used has a 3/8 to 1/2 square shaft, about a foot long, with a good sized handle; worked well. It was also used to pry/split firewood.
RV There yet??
Old 05-22-2013, 11:43 AM   #52
I just did them by hand; couldn't figure out how the screwdriver would help. Maybe when they get stiffer with age. The stabilizers were great- sure made set up simple, and two fewer things to store inside the trailer. Plus the trailer felt more stable than with the crank-up type.
Old 05-22-2013, 11:49 AM   #53
Mostly what the screwdriver/lever handle does, Bobbie, is snug up the jack- it can also make small corrections in off-level by ratcheting up a notch or two.
You just stick the handle in the hole immediately below the edge of the top half of the leg and pump down. (It goes through at a downwards-angle to/through the hole in the opposite side of the leg). Leverage lifts to lock in the next position.
Repeat for more elevation!
Francesca
Old 05-22-2013, 12:28 PM   #54
I just snugged up by raising the tongue wheel jack. Same as I did with the old jacks.
Old 05-22-2013, 11:12 PM   #55
Trailer: Casita 2001 spirit
Newbie here. Boy, I tried those Casita swing down jacks when I was bringing "Eggbert" home from purchase. I could not get them retracted. I am missing the bar. Luckily was at a friends in AZ & we got them up.
Should these things be greased or oiled for ease of op? I purchased a bumper mount with swing down arms & a rachet & webbed strap. Works for me, but I want to be like the rest of you guys.
Also did the a__teakettle when admiring the new rear overhead cab't door-here in CA we thought it was the "Big One". Had a good laugh.
Currently camped in driveway w/stabilizers deployed. )
e
partslady9 is offline   Reply With Quote
Old 05-23-2013, 12:06 PM   #56
What do you mean by "couldn't get them to retract", Elaine?
If they're the Atwood-type, releasing the tension on the lever allows one to push the foot part up into the top half of the leg- then just swing up 'til they latch. It's easier to do with a rod of some kind, which I also find necessary for getting them down in the first place. (Used to push against the leg to release tension on the holding spring)
By the way, speaking of being a Newbie:
When I first got my Trillium I cussed and swore about the "design of the jacks" because, dimwit that I am, I thought you had to beat on them from above to get them down! I don't know why they lasted as long as they did with that treatment, and don't remember exactly when I figured out different...
But I DO know why I eventually broke one 'cause it flopped open on the road one day, the holding tab having failed due to my years of abuse...
Onward through the fog!
Francesca
ok to level with (built-in) rear jacks, for winterizing? Azer Care and Feeding of Molded Fiberglass Trailers 45 11-21-2012 11:02 AM
Adding water heater under rear couch seat. dylanear Plumbing | Systems and Fixtures 16 05-28-2012 03:30 PM
Scamp rear leveling Jacks length? Roger Harshaw Towing, Hitching, Axles and Running Gear 2 04-20-2009 02:23 PM
Rear Jacks - Am I missing a part? Sheryl M Problem Solving | Owners Helping Owners 15 10-17-2007 10:01 AM
rear stabilizing jacks Mo22 Problem Solving | Owners Helping Owners 23 05-18-2007 03:16 PM
» Trailer Showcase
TBD
frankster
trilli
jokra
