Adding Solar Panels - Page 2 - Fiberglass RV
Old 08-13-2009, 03:23 PM   #15
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
Found some of the posts, Solar VHB
Thanks Greg. This is just what I want to do.
Old 08-13-2009, 03:56 PM   #16
Chester Taje's Avatar
Mike----I am really glad you asked that question. Lots of great info in this thread.
Old 08-14-2009, 01:23 AM   #17
Mike,
The best place I've found for buying VHB tape is McMaster-Carr. The have a huge selection and you can buy smaller rolls.
Good luck.
Morgan is offline   Reply With Quote
Old 08-14-2009, 06:24 AM   #18
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
http://www.itapestore.com/index.asp?PageAc...ustom&ID=19
Try this stuff.
Old 08-14-2009, 08:54 AM   #19
Try this stuff.
<span style="font-size:12pt;line-height:100%">Velcro?</span>
Old 08-14-2009, 05:31 PM   #20
Mike,
Good luck.
Morgan, Would you feel comfortable using VHB tape to hold your solar panels on?
Old 08-15-2009, 04:27 PM   #21
Trailer: 2006 (25B21RB) 21 ft Bigfoot / Dodge 2500 Diesel
Mike,
I too hesitated about the mounting method to use when I installed two 80 watt panels on my Bigfoot last year. After much research and deliberation, I decided on the VHB tape. I used much larger Z brackets than were supplied with my panels. The Z brackets I used have a contact area of 2 x 4 inches vs. the 1 x 1 inch supplied with panels. See attached pictures.
After one year and 4,000 miles, I have had no problems. The panels are very secure and feel like they would be difficult to remove. I will be at the Bigfoot Rally this year where you could take a closer look if you are attending.
I still plan on writing a detailed procedure on my solar installation.
Dean
Dean & Mary is offline   Reply With Quote
Old 08-15-2009, 04:36 PM   #22
I would.
With the caveat Gina raised; clean, clean, clean.
And Dean illustrates a good point; larger surface area means better adhesion.
Old 08-16-2009, 12:42 AM   #23
Thanks Dean & Morgan. I really appreciate the feed back.
Old 08-16-2009, 06:57 AM   #24
Why don't you just tell Lori to handle it; you know she'll do it right.
Old 08-16-2009, 11:56 PM   #25
She is in charge of the important stuff and is letting me play with this.
Old 08-17-2009, 10:18 AM   #26
Where would you recommend I buy my solar panels from?
Old 08-17-2009, 08:25 PM   #27
After checking with another on-line friend I am considering this system.
http://www.amsolar.com/am100.html
Old 08-18-2009, 10:33 AM   #28
The MPPT technology in a Solar controller is worth the money.
solar, solar power
Solar Panels For My Home D Tharp General Chat 3 04-25-2010 01:15 PM
Solar Charger and Panels Frederick L. Simson Modifications, Alterations and Updates 109 08-11-2008 10:41 PM
Solar panels on eBay peterh Care and Feeding of Molded Fiberglass Trailers 8 08-07-2008 07:43 PM
Solar Panels Barbara Gardin Electrical | Charging, Systems, Solar and Generators 7 06-02-2007 09:30 PM
Solar Panels Legacy Posts Electrical | Charging, Systems, Solar and Generators 13 04-24-2003 09:09 AM
