Adhesive question - Fiberglass RV
Old 11-17-2017, 04:01 PM   #1
Trailer: Hunter compact
Adhesive question
So I just gutted out this Hunter camper. Where the two molds meet there was an obvious sag on one side. Iíve decided to pry to the pieces apart to even everything out. Now Iíve got two questions: what would be the best way to hold these two pieces together? Adhesive, fiberglass strips on the inside, screws/bolts? And whatís the best way to cover all the screw holes along the edges? I will be covering the outside overlap with an aluminum trim once all is put back and painted. First time working with Fiberglas. Any advice is surely appreciated. Thanks.
Tyoni
0B3E0CBB-3791-461B-AB82-F65453A9B696.jpg   467B0ABA-38C5-405E-9BF3-E6CF3BFC4A32.jpg
Tyoni A is offline   Reply With Quote
Old 11-17-2017, 05:22 PM   #2
Definitely use fiberglass strips on the inside. Many people have also chose to use a fiberglass strip on the outside as well.
Fiberglass cloth does come in ribbon like rolls of varying widths. Those rolls are called "fiberglass tape" and they are much easier to work with than hand cutting strips from a large sheet of fiberglass cloth. Once the resin has cured you can sand the slightly raised woven edge of the tape to blend it seamlessly into the surface.
As to plugging the holes.... as are doing a fresh layer of materials it is best to use like materials with like materials. In other words use a compatible hole filler that goes with the resin type that you will be securing the fiberglass tape with.
As I personally like to use epoxy resin I fill small screw holes with Epoxy Putty Sticks, the kind you knead to mix the inside layer with the outside layer of material.
If you are using polyester fiberglass resins then you can use Bondo types of filler that work well with the polyester resins which you mix up and trowel into the holes to level the surface.
I choose epoxy resin because it has more strength and you can get versions of it with longer open time. However it is also the more expensive type of resin.
You can make the job of applying the tape easier faster as well as a whole lot less messy. I learned this method of application from a professional marine fiberglass repair shop. Do as follows:
Cover a table top surface with a sheet of plastic. Then roll out a length of the fiberglass tape on that surface. Pour some of the resin along that length of tape. Using the small flexible squeegees sold for fiberglass work push that resin into the tape. Use just enough resin so that see the fiberglass tape turn from white to clear. You will quickly figure out if you put on too much if it drips resin all over the place when you lift up the tape. Then with a partner lift the ends of the tape up apply it over the seam line using the squeegee smooth it into place. After it sets you can squeegee more resin onto the tape surface if needed.
If you are really worried about the strength of the join you can put a second layer of fiberglass tape on the interior of the trailer only. To do that purchase the fiberglass tape rolls in two different widths. Put the narrow tape on first then apply the wider tape on as a second layer of fiberglass cloth. Having that staggered width of wider over narrower makes for a much smoother surface finish rather than stacking two layers of the same width on top of each other.
It is not all that bad of a job to do with this method. Do work with a partner if you can as it will make it go much easier for handling the installation of the fiberglass tape. That tape cost more than sheets of cloth but it is so very much worth the extra expense versus dealing with fraying edges of glass fibers which come apart from the weave while spreading out the resin. Quick, neat and easy versus a messy struggle.
Old 11-21-2017, 12:55 PM   #3
Thanks for the detailed reply. Very useful and answered my questions. Today I will start with filling holes and cracks. I’m usung polyester resin and fiberglass mat. Ive read up on a bunch of threads here and plan on following instructions. This is my first time using anything fiberglass. Thanks again!
Adhesive question concerning floor replacement LanM Problem Solving | Owners Helping Owners 5 08-07-2010 05:30 PM
Ensolite adhesive removal TorreyT Problem Solving | Owners Helping Owners 9 04-27-2007 05:25 AM
Adhesive removal Ron S. Problem Solving | Owners Helping Owners 16 03-25-2007 07:11 AM
Adhesive Legacy Posts Problem Solving | Owners Helping Owners 7 07-29-2003 11:55 AM
Adhesive to glue foam cushions together? Legacy Posts Problem Solving | Owners Helping Owners 4 03-12-2003 08:37 PM
