Hi everyone, my 1992
scamp trailer project has kicked off and I found myself in need of a rear floor.
I've read in one of the resto threads that someone used pl300 adhesive when replacing the floor to glue it back to the hull on the underside. I plan on glassing the joint on the top of the floor but want to use an adhesive on the underside for obvious reasons
My question is: I bought a tube of pl300 and it says "foamboard adhesive". Is this the right stuff since I'm gluing resin coated plywood to
fiberglass? I also picked up a tube a pl375 heavy duty adhesive in case the 300 was not correct. Which should I use to glue the underside seam of the flooring to the
scamp shell?
Thanks in advance for the reply.
