Advanced Scamp Electrical Question - Page 2 - Fiberglass RV
Old 03-08-2016, 02:08 PM   #15
Raz
Raz's Avatar
Vermont
Originally Posted by Captleemo View Post
Dielectric means it won't conduct electricity but won't hinder conductivity so it actually is not an insulator because if it was it would hider conductivity.
Dielectric
From Wikipedia, the free encyclopedia
A dielectric material (dielectric for short) is an electrical insulator that can be polarized by an applied electric field. When a dielectric is placed in an electric field, electric charges do not flow through the material as they do in a conductor, but only slightly shift from their average equilibrium positions causing dielectric polarization.
Old 03-08-2016, 02:09 PM   #16
The dielectric condrumum. It is an insulator. The contacts of the bulb make contact with the hot and return contact in the receptacle and the dielectric insulation grease surrounds everything to keep water and air out. At some auto parts stores it comes with bulbs and trailer connectors.
Old 03-08-2016, 02:34 PM   #17
Dielectric grease has been discussed several times here. The more important discussion should be understanding connector technology. There's something called a "gas tight seal" associated with connectors. When the connectors are put together there's enough friction that a few molecules of the mating surfaces is displaced, this removes contamination and allows the connector to function. When dielectric grease is applied to the connector the grease is just another contaminate that is removed where the connection happens. The rest of grease keeps moisture out the connector. Since dielectric grease is an insulator it can be used in mulitcircuit connectors and not provide a connection between the circuits.
Old 03-08-2016, 02:42 PM   #18
Trailer: Casita 17 ft DLX SD
The substance used when terminating or making electrical connections is Pentrox .It is required when terminating aluminum wires because aluminum oxidation does not conduct .Pentrox is a conductive grease and metal paste . Ideal makes small plastic squeeze bottles of Pentrox. We also used Pentrox on the screw threads of intermediate and rigid conduit to prevent galling and insure conductivity. Pentrox is also used on the screw threads of lamps and lamp holders used in damp /wet locations .Pentrox is not a dielectric grease and is UL listed .
steve dunham is online now   Reply With Quote
Old 03-08-2016, 04:03 PM   #19
Raz
Raz's Avatar
Vermont
Byron's suggestion is that the pressure of the contacts will push the grease out of the way and allow continuity. My thought is that you are likely to have a high resistance contact at best. And if the grease has been removed by the pressure of the contacts then what is it protecting. Perhaps the auto bulb folks intend it to be put on the glass to form a seal between the bulb and the socket. But I'm sure there's no instructions so we can only guess. take care, Raz
Old 03-08-2016, 04:08 PM   #20
Trailer: 1978 Burro
electrical troubleshooting
Originally Posted by gordon2 View Post
I call this an advanced question because this one really has me stumped and will likely require your very best thinking cap also if you choose to try your skill at solving the puzzle. Only read further if you like a challenge.
The outside front light (over the propane tank and battery) on my Sept 2015 vintage Scamp was working fine last fall. On the off season, I installed a TriMetric meter and companion solar charger with a connection to a receptacle. All of this was put in the compartment under the front sofa (door side). While load testing the solar charger by turning on every 12 volt item at once (and while off shore power), I discovered that the front outside light would not come on.
It is certainly possible that I pulled a connector loose or something while installing the meter and solar wiring, so I started with standard troubleshooting steps.
Removed bulb and noticed that since Scamp uses such cheap light fixtures the bulb socket was a little corroded after only six months of being outdoors. Cleaned it all up well, still no light.
Checked the bulb visually and for continuity. It checked out as good.
Substituted a LED bulb and there was light. Operation was normal with the LED bulb.
Tried another incandescent bulb with same results as the first bulb, no light.
Hooked up both incandescent bulbs to a 12 volt supply with alligator clips and they both lit up fine. The bulbs are good.
I can actually see the center pin make contact when I put the bulbs in. Everything sure seems to be making good contact.
Measured the voltage at the blub socket (with the switch on) and read 12.7 VDC at the center positive contact and the part of the socket where the bulb base and tab make contact.
Scratched head since that seemed to be the next appropriate step.
At this point in my story I might offer kudos to those of you who 1: noticed that the LED bulb with low current draw worked fine but the higher amperage incandescent did not, and then, 2: concluded that maybe there is a bad connection that is allowing enough power to get the 12.7 VDC reading but is not good enough to pass the amount of current which the incandescent needs. If that were the case I would expect the voltage to drop under the heavier load, so next step…
I removed the wire nut off the positive wires, made sure they were well twisted together, and hooked up the multimeter positive lead to the positive wires. With the incandescent bulb in and the switch on, I read the voltage with the negative meter lead on the outside of the socket, and then on the base of the bulb. Voltage was constant when the switch was on - there was no voltage drop. At this point there was only one more test I could think of and it was just a little risky.
With extreme care as to not cause a short, I removed both wire nuts in the light fixture to expose the positive and negative feed wires and touched them to the incandescent bulb, which I almost dropped when there was a small spark and the bulb lit up! So we know the wiring to the fixture is OK.
That means the fixture seems to be the issue. It worked fine with an incandescent bulb a few months ago but no longer does. It does work with LED bulbs however which are equivalent with the same base. Explain that!
Gordon, I have to commend you on your job troubleshooting your electrical problem!
I have seen time and time again someone who checks for voltage with a meter and thinks they have "voltage" there. Well you proved beyond a doubt that you had a connection problem by lighting up an LED but not an incandescent lamp. A voltmeter would have also shown "voltage" was there too.
Trouble is testing something without applying a sufficient current drawing load can really fool a person.
A good friend of mine replaced a 275 dollar fuel pump in his brother's truck only to find out it was a connection problem in the wiring harness. Voltmeter "told" him there was 12 volts present. Couldn't take the pump back either.
DuaneQ is offline   Reply With Quote
Old 03-08-2016, 04:10 PM   #21
Well well well. this turned out to be an Advanced Scamp Electrical discussion after all!
But I just wanted my light to come on
Good news is that it looks like I get the needed replacement parts under warranty.
Old 03-09-2016, 05:25 AM   #22
Originally Posted by DuaneQ View Post
I have seen time and time again someone who checks for voltage with a meter and thinks they have "voltage" there. ...
According to Glen's favorite authority (Wiki ), voltage is "is the difference in electric potential energy"
The key word is potential! You might have the potential have light, heat or whatever but there is no guarantee from voltage alone.
Interestingly (to me at least), it seems I have a similar problem in my house wiring. The last two outlets on one circuit "shut down" when high current devices are used on them. For example, after using a 120 VAC jack hammer, even a radio will not work in the outlet. There is "residual" voltage around 50 VAC and it returns to "normal" after some time, only to fail when high current draw occurs again. The GFCIs and the circuit breaker have been ruled out as suspects. The concern is a high resistance point than can spell serious trouble so it needs to be fixed soon. In the mean time that circuit is not used.
Old 03-09-2016, 06:35 AM   #23
Trailer: 2014 Escape 21
Virginia
Gordon
I may be wrong but I think you can replace the switch with the fixture installed. I would try that rather than R&R the fixture unless you find a much better quality light fixture. Seems like most trailer mfg. use these same fixtures. They are also prone to turn yellow with age, you may want paint your current fixture while messing with it. Replace the switch, drill a drain hole in the bottom and you should be good to go.
Eddie
Eddie Longest is online now   Reply With Quote
Old 03-09-2016, 08:51 AM   #24
Gordon2, it sounds like you have a loose connection in your house wiring, possibly a loose neutral. Always fun chasing those down. I know you said that you sprayed your RV light switch with some contact cleaner but I would still give it a shot of WD-40. Thats always worked for me on a corroded connection. My garage door remote seems to quit working every once and awhile so I check the battery but it usually turns out to be the tiny little micro switch inside the remote. I give it a spritz of WD-40 and I'm back in business, every time. I live on the Gulf coast so the high humidity is probably what causes the problem.
Lee
Captleemo is offline   Reply With Quote
Old 03-09-2016, 10:28 AM   #25
Trailer: 1978 Burro
voltage drop testing
Gordon, the best way to test for load problems is to measure the voltage at your load with it connected. This way you will be able to tell if you have a poor connection, too small gauge wire etc. Hope this helps.
Old 03-09-2016, 03:54 PM   #26
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
I came kind of late to this thread, but let me throw my mechanical engineering two cents in. The advantage of the dielectric grease should be that the mechanical parts of the switch will work better and possibly provide higher contact pressure, exactly where it matters. Being dielectric, it is not going to cause a short, or leakage in case of multi contact switches, which is actually not relevant here. Pretty much the same goes for WD40. I bet it is a pretty good dielectric as well.
Old 03-09-2016, 04:06 PM   #27
Paul O.'s Avatar
ex VT, now CO
I might be confused about the terminology but this is what I was referring to. Used it for years on all sorts of electrical contacts, such as the trailer to tug umbilical cord.
This is from the link you provided:
When the connection is tightened, the grease is displaced, leaving a layer of zinc and graphite filling in the surface imperfections of the interface.
  • Makes connections more reliable
  • Makes connections more weatherproof
  • Protects connections from corrosion
  • Reduces temperate rise
  • Low sulphur content
  • Non-reactive, no gassing in storage
  • Brushable over a wide temperature range
  • Sticks to wet joints
Both zinc and graphite are conductors, so I bet this is only suitable for a high power connection that is made once and left alone. Not a switch.
Old 03-09-2016, 04:37 PM   #28
Gordon2: I had that problem on a house circuit. It turned out that a hot wire was not tightened down and it would work until the wire got hot which caused it to move and the light would dim or shut off completely. Check the connections.
electrical, scamp
My new 13' Scamp & Electrical question Unoman Electrical | Charging, Systems, Solar and Generators 11 01-24-2013 07:23 AM
Advanced Search Titles Only Broken JohnF Forum Admin, News & Announcements 4 10-15-2011 08:08 PM
13' Scamp basic electrical question Nick Glenney Problem Solving | Owners Helping Owners 3 04-05-2009 08:55 PM
Dumb Electrical Question Bob H Problem Solving | Owners Helping Owners 2 12-25-2006 05:10 PM
electrical question stan s. Problem Solving | Owners Helping Owners 2 08-10-2006 10:25 AM
