Advanced Scamp Electrical Question - Fiberglass RV
Old 03-07-2016, 06:48 PM   #1
I call this an advanced question because this one really has me stumped and will likely require your very best thinking cap also if you choose to try your skill at solving the puzzle. Only read further if you like a challenge.
The outside front light (over the propane tank and battery) on my Sept 2015 vintage Scamp was working fine last fall. On the off season, I installed a TriMetric meter and companion solar charger with a connection to a receptacle. All of this was put in the compartment under the front sofa (door side). While load testing the solar charger by turning on every 12 volt item at once (and while off shore power), I discovered that the front outside light would not come on.
It is certainly possible that I pulled a connector loose or something while installing the meter and solar wiring, so I started with standard troubleshooting steps.
Removed bulb and noticed that since Scamp uses such cheap light fixtures the bulb socket was a little corroded after only six months of being outdoors. Cleaned it all up well, still no light.
Checked the bulb visually and for continuity. It checked out as good.
Substituted a LED bulb and there was light. Operation was normal with the LED bulb.
Tried another incandescent bulb with same results as the first bulb, no light.
Hooked up both incandescent bulbs to a 12 volt supply with alligator clips and they both lit up fine. The bulbs are good.
I can actually see the center pin make contact when I put the bulbs in. Everything sure seems to be making good contact.
Measured the voltage at the blub socket (with the switch on) and read 12.7 VDC at the center positive contact and the part of the socket where the bulb base and tab make contact.
Scratched head since that seemed to be the next appropriate step.
At this point in my story I might offer kudos to those of you who 1: noticed that the LED bulb with low current draw worked fine but the higher amperage incandescent did not, and then, 2: concluded that maybe there is a bad connection that is allowing enough power to get the 12.7 VDC reading but is not good enough to pass the amount of current which the incandescent needs. If that were the case I would expect the voltage to drop under the heavier load, so next step…
I removed the wire nut off the positive wires, made sure they were well twisted together, and hooked up the multimeter positive lead to the positive wires. With the incandescent bulb in and the switch on, I read the voltage with the negative meter lead on the outside of the socket, and then on the base of the bulb. Voltage was constant when the switch was on - there was no voltage drop. At this point there was only one more test I could think of and it was just a little risky.
With extreme care as to not cause a short, I removed both wire nuts in the light fixture to expose the positive and negative feed wires and touched them to the incandescent bulb, which I almost dropped when there was a small spark and the bulb lit up! So we know the wiring to the fixture is OK.
That means the fixture seems to be the issue. It worked fine with an incandescent bulb a few months ago but no longer does. It does work with LED bulbs however which are equivalent with the same base. Explain that!
Old 03-07-2016, 07:30 PM   #2
The LED will sometimes work when you have a coroded connection like on the ground side. You need to remove the bulb and do a resistance check on both the hot side and ground side.
Old 03-07-2016, 08:21 PM   #3
Radar1's Avatar
I agree with your assessment that the fixture is at fault, especially if the wires that end at the fixture will light the incandescent bulb, but it won't work in the fixture itself. Perhaps some dielectric grease on the switch contacts might help and keep corrosion at bay?
Sharpsburg, GA
radar1-scamping.blogspot.com
Old 03-07-2016, 08:31 PM   #4
The contacts in the light switch may be corroded. Jumper the switch and see how it works.
Eddie
Old 03-07-2016, 08:42 PM   #5
All good suggestions that point to a bad connection, probably due to corrosion, in the fixture. I'll look at it again in the daylight but if this happens after only six months I think I might just have to upgrade the fixture.
Old 03-08-2016, 10:18 AM   #6
Might not hurt to give the light socket and the switch a spritz of WD-40. If corrosion is the problem that will help. Also if you check an auto parts store or online there are dielectric greases that are made for coating the metal bases of automotive bulbs to prevent corrosion.
Lee
Captleemo is offline   Reply With Quote
Old 03-08-2016, 10:45 AM   #7
Trailer: Still Looking
Alabama
The LED bulb draws way less amperage, so yes, if you had a bad connection the power hungry incandescent may not light up.
Bullington is offline   Reply With Quote
Old 03-08-2016, 01:34 PM   #8
We have multiple winners for this puzzle. I don’t know who said this was so difficult!
(Oh wait, I think I said that )
@Eddie Longest: You sir were dead on. Jumper-ed the switch and the light works fine.
@ Captleemo: Removed switch and sprayed it with contact cleaner that I have here (the kind that is used on old style TV tuners and potentiometers. That helped, but the switch is still flaky. it works most of the time, and always lights if I bypass the switch.
@ Radar1 and Captleemo: Good idea - and I do have dielectric grease here too. Its something all trailer owners should keep around. It will help but the corrosion on the base of the bulb was not the problem (or maybe only part of the problem).
@ Darwin Maring: Resistance of the switch only was all of .2 ohms with no load.
So.. bad switch allowed enough power for the LED to work but not the incandescent bulb.
By the way, I found so much sawdust and stuff in the light fixture that I am sure it trapped water on the bottom where the switch is. It looks like Scamp did a lot of sanding, cutting and fiberglass work while the lens was off and never cleaned it out when the light install was finished. If I can’t get a replacement switch for free under warranty than I will spring for a better light fixture.
Thanks to all.
Old 03-08-2016, 01:56 PM   #9
The following is from Wiki. Dielectric grease does not conduct electricity so it's not intended for use on the contacts.
Dielectric grease is electrically insulating and does not break down when high voltage is applied. It is often applied to electrical connectors, particularly those containing rubber gaskets, as a means of lubricating and sealing rubber portions of the connector without arcing.
A common use of dielectric grease is in high-voltage connections associated with gasoline engine spark plugs. The grease is applied to the rubber boot of the plug wire. This helps the rubber boot slide onto the ceramic insulator of the plug. The grease also acts to seal the rubber boot, while at the same time preventing the rubber from becoming stuck to the ceramic.
Old 03-08-2016, 02:32 PM   #10
I might be confused about the terminology but this is what I was referring to. Used it for years on all sorts of electrical contacts, such as the trailer to tug umbilical cord.
Old 03-08-2016, 02:36 PM   #11
That says it enhances conductivity, so should do the trick.
Old 03-08-2016, 02:43 PM   #12
Raz
Raz's Avatar
In the electrical world a dielectriic is an insulator. Dielectric grease has the resistivity of glass. That said there are two EE's on this board, Byron and myself. Byron loves the stuff. I think its a mistake. Good luck Raz
Old 03-08-2016, 02:50 PM   #13
Dielectric means it won't conduct electricity but won't hinder conductivity so it actually is not an insulator because if it was it would hider conductivity.
Lee
Old 03-08-2016, 03:04 PM   #14
Wiki entry says it is an insulator.
And defines insulator: An electrical insulator is a material whose internal electric charges do not flow freely, and therefore make it nearly impossible to conduct an electric current under the influence of an electric field. This contrasts with other materials, semiconductors and conductors, which conduct electric current more easily. The property that distinguishes an insulator is its resistivity; insulators have higher resistivity than semiconductors or conductors.
Old 03-08-2016, 03:08 PM   #15
Raz
Raz's Avatar
Dielectric
From Wikipedia, the free encyclopedia
A dielectric material (dielectric for short) is an electrical insulator that can be polarized by an applied electric field. When a dielectric is placed in an electric field, electric charges do not flow through the material as they do in a conductor, but only slightly shift from their average equilibrium positions causing dielectric polarization.
Old 03-08-2016, 03:09 PM   #16
The dielectric condrumum. It is an insulator. The contacts of the bulb make contact with the hot and return contact in the receptacle and the dielectric insulation grease surrounds everything to keep water and air out. At some auto parts stores it comes with bulbs and trailer connectors.
Old 03-08-2016, 03:34 PM   #17
Dielectric grease has been discussed several times here. The more important discussion should be understanding connector technology. There's something called a "gas tight seal" associated with connectors. When the connectors are put together there's enough friction that a few molecules of the mating surfaces is displaced, this removes contamination and allows the connector to function. When dielectric grease is applied to the connector the grease is just another contaminate that is removed where the connection happens. The rest of grease keeps moisture out the connector. Since dielectric grease is an insulator it can be used in mulitcircuit connectors and not provide a connection between the circuits.
Old 03-08-2016, 03:42 PM   #18
The substance used when terminating or making electrical connections is Pentrox .It is required when terminating aluminum wires because aluminum oxidation does not conduct .Pentrox is a conductive grease and metal paste . Ideal makes small plastic squeeze bottles of Pentrox. We also used Pentrox on the screw threads of intermediate and rigid conduit to prevent galling and insure conductivity. Pentrox is also used on the screw threads of lamps and lamp holders used in damp /wet locations .Pentrox is not a dielectric grease and is UL listed .
Old 03-08-2016, 05:03 PM   #19
Raz
Raz's Avatar
Byron's suggestion is that the pressure of the contacts will push the grease out of the way and allow continuity. My thought is that you are likely to have a high resistance contact at best. And if the grease has been removed by the pressure of the contacts then what is it protecting. Perhaps the auto bulb folks intend it to be put on the glass to form a seal between the bulb and the socket. But I'm sure there's no instructions so we can only guess. take care, Raz
Old 03-08-2016, 05:08 PM   #20
Trailer: 1978 Burro
electrical troubleshooting
Gordon, I have to commend you on your job troubleshooting your electrical problem!
I have seen time and time again someone who checks for voltage with a meter and thinks they have "voltage" there. Well you proved beyond a doubt that you had a connection problem by lighting up an LED but not an incandescent lamp. A voltmeter would have also shown "voltage" was there too.
Trouble is testing something without applying a sufficient current drawing load can really fool a person.
A good friend of mine replaced a 275 dollar fuel pump in his brother's truck only to find out it was a connection problem in the wiring harness. Voltmeter "told" him there was 12 volts present. Couldn't take the pump back either.
DuaneQ is offline   Reply With Quote
electrical, scamp
My new 13' Scamp & Electrical question Unoman Electrical | Charging, Systems, Solar and Generators 11 01-24-2013 08:23 AM
Advanced Search Titles Only Broken JohnF Forum Admin, News & Announcements 4 10-15-2011 08:08 PM
13' Scamp basic electrical question Nick Glenney Problem Solving | Owners Helping Owners 3 04-05-2009 08:55 PM
Dumb Electrical Question Bob H Problem Solving | Owners Helping Owners 2 12-25-2006 06:10 PM
electrical question stan s. Problem Solving | Owners Helping Owners 2 08-10-2006 10:25 AM
