advice re: awnings for 13' Trillium - Page 3 - Fiberglass RV
Old 03-27-2013, 07:05 PM   #29
Trailer: 1977 Trillium 4500
Manitoba
Hey Randy, What is the size of your Carefree awning on the 4500 trillium? I was lucky to find a trillium last spring, it came with the original awning, but I want to replace it. Thanks in advance for your help.
lucille is offline   Reply With Quote
Old 03-28-2013, 09:01 AM   #30
Trailer: (4) Trillium 4500, (4) Trillium 1300, (1) Scamp,(1) Burro 16'
Ardmore, Alabama
The awning I have on my 4500 is a 9'er....................
Randy Bishop is offline   Reply With Quote
Old 04-03-2013, 07:46 PM   #31
Manitoba
Randy, Confusing for a newbie... I can't seem to find a 9'er. Carefree sells 8'5" or 9'10". Offhand do you know the length of the awning rail on the Trillium 4500?
Old 04-03-2013, 09:46 PM   #32
Roy in TO's Avatar
Carefree went metric a few years back. Some RV places have some NOS (New Old Stock) Imperial sized awnings. Keep your eye open for awnings on kijiji and craigslist. Carefree bag awnings were stock on Rockwood tent trailers.
Old 04-03-2013, 10:03 PM   #33
David Tilston's Avatar
Ironic that the metric awning does not fit the 4500mm trailer.
Old 04-03-2013, 11:00 PM   #34
Roy in TO's Avatar
The 3 meter should fit.
My 4500 is still in storage so I can't personally confirm for sure right now. When Carefree switched to metric sizing they also started measuring differently. Your 9' awning has about a 9'6" bag at the widest point, they provided the imperial measurement of the awning not the bag. The 3m bag awning is just shy of 10' (9'10") and has about a 9'4" awning inside the bag, they measure the metric bag at the widest point not the awning. Lucille said she needs 3" extra rail on either side of the bag to fit, so that means she needs 10'4" available to fit the rail. BUT the bag tapers in, so she actually needs less.
If I recall those few inches are somewhere in the range of where the body starts to curve on the 4500. Randy has pictures posted of a Carefree on his 4500 on post #15 of this thread. Those few inches look close enough to want to measure both the awning and trailer to be sure.
Old 07-23-2015, 09:31 AM   #35
Trailer: 1976 trillium
hi can any one help me i have a bag awning on my 13 ft trillium but there seems to be no brackets on camper it has four one inch tubing bars on it i think it might be a carefree but not sure and cannot find any name on it thanks old yeller
old yeller is offline   Reply With Quote
Old 07-23-2015, 09:43 AM   #36
Cool
thetubing bars are square
Old 07-23-2015, 10:41 AM   #37
Do two of the bars have a plastic ball on the end. They would be the rafter tubes and the ball goes into a socket on the trailer, one at each end of the rail. The other tubes would be the legs at the outer end of the awning
mary and bob is online now   Reply With Quote
Old 07-23-2015, 10:58 AM   #38
hi mary and bob the tubes are square and there is no sockets on the trailer i probably will have to take it to an rv shop i cannot find a name on it oooooH what a bill coming. thanks for the info. old yeller in on
Old 07-23-2015, 12:46 PM   #39
WA
Here's what I did when we lost our awning in Utah recently to a big gust of wind. I removed the bag entirely and removed the rivets that held the aluminum strip in place. These I sent to the landfill because I couldn't think of anything clever to do with them. Next, I filled in the rivet holes with sand-able marine filler, waited for it to dry, then wet-sanded the small area to smoothe. Then I ordered marine grade adhesive snap studs from Sailrite (YKK® SNAD® Clear 40mm Adhesive Backed Flexible Base Stud) and a little can of the 3M Tape Primer 94 - Adhesive Promoter. I put a little primer over the patch, a circle just bigger than the stud, let it dry, then put on the 6 snap studs over the old rivet holes. These studs are really strong and have a clear silicone base so they blend pretty well into the roof. Then I bought an EZ awning from the bus depot for a around $150. (Ezy Awning - Beige) This awning has two legs on the side away from the trailer, an "umbrella" top, and no legs on the trailer side. Then, we made 6 little rings out of dog collar ribbon -- such that they snap together to form a ring, and have a third snap that snaps to the studs mounted on the Trillium. So you snap the rings to the Trillium and then put the rings around the awning's horizontal pole -- the trailer side with no legs. Voila, as they say in France. It works really well. It's lightweight, cute, and has enough give that it won't rip your trailer apart if a wind comes up in the middle of the night. If I can figure out how to post pictures I will. This is a relatively inexpensive and lightweight solution to this problem, and you only have to be a little handy. ( :
Colleeno is offline   Reply With Quote
Old 07-23-2015, 01:36 PM   #40
WA
I couldn't take completely clear pics as the Trilly is parked in our driveway. The awning had to go over a few little bushes.
Old 07-23-2015, 01:37 PM   #41
Ellpea in CA's Avatar
Whoa, Colleen, this sounds like a wonderful (and easy-to do) setup. I REALLY hope you can post some photos... with lots of detail.
Am I understanding that you have been able to essentially "glue" snap studs to the outside of your trailer without drilling through? And that the adhesive is strong enough to hold your awning?
It also looks like the vendor sells "suction cups" that attach and are strong enough to hold the awning. Does anyone have experience with these (they sound perfect for what I need!)?
LP
Ellpea in CA is offline   Reply With Quote
Old 07-23-2015, 01:40 PM   #42
WA
I'm trying to post pics now. Hope it works
trillium
Trillium over the door cracks, need advice Raz Problem Solving | Owners Helping Owners 14 08-26-2011 06:22 AM
Looking for some advice re: awnings Denise T Hi, I am.... 3 08-19-2011 11:28 PM
shopping for awning for trillium 1300 - looking for advice Kevin Poll Modifications, Alterations and Updates 12 07-15-2011 10:36 AM
Need advice: New Trillium with a hinge problem Raz Problem Solving | Owners Helping Owners 13 12-29-2010 03:48 AM
Awnings? Jonathan S. Care and Feeding of Molded Fiberglass Trailers 8 06-01-2009 07:52 PM
