Advice repairing caved in Scamp 13 roof - Page 4 - Fiberglass RV
Old 01-31-2012, 11:35 PM   #43
Name: Norm I want to thank all the Kings horses and all the Kings men
Trailer: 73 Scamp 13'
Thank you for the kind words and sorry I haven't posted pictures yet. I bought the trailer in it's broken down state so insurance is out. I've started sanding the new fiberglass on the outside and it's blending pretty well but I think I will probably need a little body filler to level some problem areas. I removed the rear window and repaired the top edge where the cracks met the window. I have also been adding 5" wide strips of fiberglass mat across the inside of the roof to repair some sags that I think were there before the "great cave in". The areas I have repaired are considerably thicker than the original fiberglass and it actually seems stronger than the original. I will post some pics when I feel it's more presentable.
Ngrimm is offline   Reply With Quote
Old 02-01-2012, 07:22 AM   #44
Trailer: 13 ft Boler 1986
Like Donna says, we like to see all stages of the work (nosey you know) so please let us in on each stage as it goes. Might help somebody else.
Vivian L is offline   Reply With Quote
Old 02-01-2012, 01:29 PM   #45
Mike Magee's Avatar
Trailer: Li'l Hauley
What, no DUCT TAPE in this repair???
Did you hear about the butcher
who backed into the meat grinder?
He got a little behind in his orders....
Old 02-01-2012, 05:24 PM   #46
Pictures
The inside pics look funny since so much more light shows thru the new fiberglass. The outside cracks need just a little more filler in a few areas but are getting close. The shots of the rear show how much damage was done but it is much thicker than the original fiberglass that surrounds it. As mentioned previously, I tied it together from the inside with several layers of glass and then ground out the outside and and leveled it out with glass and resin.
Old 02-01-2012, 05:37 PM   #47
Lizbeth's Avatar
Thanks for the picture of the work in progress! It's looking like an egg again!
Old 02-01-2012, 05:44 PM   #48
Trailer: 1981 Boler
Sarnia, Ontario
looking really good. what are you going to do for paint? what are you going to use to finish the trailer with?
idiotsniff is offline   Reply With Quote
Old 02-01-2012, 07:44 PM   #49
Norm, THANK YOU for posting the in-progress pictures. We have tons of pics of finished projects, but these types of pics will truly be helpful in the future for those members who may be tackling a similar project. Nothing like "seeing" what a member may be facing, truly...
Old 02-01-2012, 11:51 PM   #50
Trailer: 1989 Bigfoot
Hey Norm, your trailer is looking great, you are back to the original shape again. I'm sure you are happy with the results. Any plans for altering the interior since you are starting with a clean slate? Keep those pictures coming.
Ken
ken h is offline   Reply With Quote
Old 02-02-2012, 07:04 AM   #51
Andrew GPSMapNut's Avatar
Trailer: Modified Trillium Jubilee
The only thing I can say is WOW! This is not a repair or restoration. It is a resurrection!
I wish to be one day at least half as good as I think I am today. Andrew Kalinowski
Andrew GPSMapNut is offline   Reply With Quote
Old 02-02-2012, 09:38 AM   #52
Well I can't take all the credit. You did see the tire cover right? I really didn't know where to start but the suggestions offered early on helped immensely . I think grinding off the ensolite adhesive was the worst part so far. I have never been so dirty or itchy. I also struggled with applying the fiberglass overhead at first. I tried whetting the repair area with resin and then sticking the dry 4" wide strips in place and brushing in the resin. I just ended up with a mess with resin running down my brush and my arm, my leg etc. Once I started reducing the strips of mat to a manageable size and whetted them before sticking them to the whetted ceiling with a brush and plastic spreader instead of my gloved hands it went pretty fast. Of course I had to overlap the shorter pieces but I don't think that will hurt anything. I'm trying to get the outside as smooth as I can to reduce the amount of Bondo needed. After the Bondo I'll use a good sealing primer and spray on some type of white marine paint but I don't know which one yet. Still a lot of work to do before then.
Old 02-02-2012, 10:05 AM   #53
Raz
Raz's Avatar
Vermont
Wow. What a nice job. Looking unbelievably good considering where you started. Thanks for the pictures. Raz
Old 02-02-2012, 09:07 PM   #54
Massachusetts
Based on those last pictures I'd name it Frankencamper, and the paint job should emphasize the scars.
Garycamper is offline   Reply With Quote
Old 02-02-2012, 10:26 PM   #55
I agree
One of a kind
And sooo cool to
Don't forget the two bolts
Siris is offline   Reply With Quote
Old 02-03-2012, 06:52 AM   #56
There are all kinds of paint out there of course, but we have several bolers here in our area, including ours, that have simply used good old TremClad.
Bizzian
Repairing hail damage to the roof Daryl R Problem Solving | Owners Helping Owners 5 07-17-2011 10:39 PM
Repairing my "76" Scamp James R Williams Problem Solving | Owners Helping Owners 2 08-22-2010 09:47 PM
Seeking your advice on a Scamp 13' purchase Bill caulway Problem Solving | Owners Helping Owners 7 08-06-2010 09:44 PM
Help with 04' used 13' Scamp: Buying advice? Mike Butteri General Chat 20 04-27-2009 10:32 PM
Seeking advice re: 19 ft. Scamp 5th Wheel Wanted: Molded Fiberglass Travel Trailers 0 01-01-1970 12:00 AM
» Trailer Showcase
Cadet
Cadet85
Amerigo
donjdart
