Alternative to Ensolite - Fiberglass RV
Old 10-03-2010, 01:57 PM   #1
Trailer: 1978 Boler B1700 RGH
Saskatchewan
I am replacing the ensolite on my 17ft Boler and found this product. Does anyone have any thoughts or advice. I thought the fact that it has a finished side of white poly was a bonus.
Double Bubble Insulation : Radiant Barrier, Reflective Foil Insulation, Bubble Insulation: EcoFoil
Thanks.
Don
Don A is offline   Reply With Quote
Old 10-03-2010, 03:27 PM   #2
Raya's Avatar
I can't comment on the bubble stuff, except I do wonder how tough the white skin would be (presuming you would plan to use that as the inner walls since you like that it is white).
I can't tell from your post: Have you ruled out new Ensolite for some reason? It sounds like it, but I thought I would ask.
Old 10-03-2010, 07:53 PM   #3
Saskatchewan
I thought because I didn't have to find a finish material for the interior side of the ensolite that it would be easier to use a product that already had a finish on it. Pretty much new at all of this.
Old 10-03-2010, 10:14 PM   #4
Raya's Avatar
I see. Well it is true that (to my knowledge) no-one has found the Ensolite with the "white" skin on it like is in Bolers/Trilliums/older Scamps, etc.
However people have installed new Ensolite and then painted it. I don't know if that is what you mean by adding a finish material, or if you thought you would have to add vinyl or something.
At any rate, new Ensolite is an option; just wasn't sure if you knew that and didn't want it, or if you were not aware that it still existed.
Raya
Old 10-04-2010, 12:12 AM   #5
Roger C H's Avatar
Ensolite is available with a vinyl coating which will preclude the need for painting. I would consult your local foam distributor. Look under "Foam and sponge rubber" in the Yellow Pages. Or try here:
Foam & Sponge Rubber - Wholesalers &/or Manufacturers in Regina, SK | Canpages
Ask for "closed cell foam with a vinyl coating."
Old 10-04-2010, 12:21 AM   #6
Raya's Avatar
Wow, Roger... sweet! Somany people from the forum (Tom, are you reading this!?) have been searching high and low for the vinyl-coated Ensolite with no luck. Do you have a name or part number or any other info?
This is great news It's going to make for some very happy campers!
Raya
(I called for, and received, samples from IR Foam Specialty in Washington and from my conversation with them they had no vinyl-skinned Ensolite like is in our trailers, unless I was given mis-information. My samples were grey/black foam that would have needed to be painted. This is like what Brad and Jenny used in their red Boler - they went to IR Foam Specialties in person - they lived nearby - and they also ended up with the grey/black foam - they painted theirs.)
Old 10-16-2010, 01:57 PM   #7
Robert Johans's Avatar
Trailer: Nest Caravans
Has anyone found a similar provider in the States?
Old 10-16-2010, 05:40 PM   #8
Raya's Avatar
Good question, but heck, I want to know more about even the Canadian provider. Roger C H, can you tell a bit more about this? People have been looking for this product for soooo long. I'm totally impressed that you were able to find it (heck, I tried but was unsuccessful; I was only able to source the uncoated type from IR Foam Specialty in Washington ), but I want to know more!
Don't leave us hanging!
Thank you,
Raya
Old 10-19-2010, 11:30 AM   #9
Roger C H's Avatar
Smile Trailer parts
Well, Trillium has the door gasket available:
Parts
As far as wall covering, this place looks promising:
Deccofelt Materials: Los Angeles California adhesive coating laminating, fabrics, foam, cork, felt, rubber, die cutting, slitting and sheeting
Old 10-19-2010, 11:39 AM   #10
Raya's Avatar
Hi Roger, and thanks for stopping back
It's this vinyl-coated Ensolite that has me so worked up. I take pride in the fact that I can find anything, but I have not been able to find it. Have you found it somewhere? You sounded so definite that I just want to be sure, because so many people have been looking for it.
(I don't actually need any now myself, as when I saw how hard it was to find I shifted my attention to trailers that did not need it, but there is a quite a group who would jump at the chance to buy some. Plus, if I ever find a Compact Jr......).
If not, I will lay this lead to rest; I just want to be sure before I do (yes, I have dogged determination when I am trying to find something ).
Raya
Old 10-29-2010, 07:23 AM   #11
Trailer: '73 Boler
Raya
What about this product called Eco Cork Foam. I saw it at a Home Depot yesterday and thought it would be a perfect replacement to the Ensolite. I don't think it's paintable, but has a very nice earthy flecked beige look. It could be paintable, depending on what side you install it (one side is glossy) It has sound dampening, insulation properties and resistance to mold, bacteria, mildew issues. Anyway, thought it would be interesting.
Link to here:Eco Cork Foam - Natural Choice Underlayment, for Laminate and Engineered Wood Floors - ECF50T3B6 - Home Depot Canada
astroboy is offline   Reply With Quote
Old 10-29-2010, 12:11 PM   #12
I wonder how well this product reacts to compound curves... I see that it comes in rolls, but will it bend in two directions simultaneously?
Old 10-29-2010, 01:13 PM   #13
Trailer: '73 Boler
good thought. I think depending on if you use the shiny side out or not? someone would have to try a sample out.
Old 11-15-2011, 06:05 PM   #14
Has anyone used anything except ensolite? Would be interested in the result (condensation and insulation)?
Also is I noticed many of the above are vapor barriers, does this cause any problems?
Nelmes is offline   Reply With Quote
Awning Alternative David Schroeder Modifications, Alterations and Updates 12 04-09-2015 09:47 PM
Alternative Way Perry Mac Donald Camp Cooking, Food & Recipes 9 02-06-2010 10:43 PM
Possible Alternative to Rat Fur or Ensolite? Pamela S. Modifications, Alterations and Updates 5 09-14-2009 07:20 AM
Another wood stove alternative Bonnie General Chat 9 12-22-2008 07:07 PM
alternative venting Refridgerator Coach George Jessup Problem Solving | Owners Helping Owners 6 10-05-2008 10:03 PM
