Aluminum seam band on Casita - Fiberglass RV
Old 06-23-2019, 07:47 AM   #1
Illinois
I had to remove a section of the belly band that covers the seam on my 84 Casita in order to fix a leak. Do you think the aluminum band has any structural purpose? The band itself, I'm assuming factory, is ill fitting and poorly executed. I think a rubber or plastic c channel gasket or trim would conform to the curves much better than the original. Obviously it wouldn't have the strength of the aluminum. I am going to put the band back on for now but contemplating removing all of it and replacing with the rubber or plastic channel. If it is merely for the looks of covering the two half seam it will be a cleaner and probably sealed better repair.
daleeb is offline   Reply With Quote
Old 06-23-2019, 07:57 AM   #2
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I think the band is cosmetic and is UV resistant. Any plastic or rubber gasket would be less UV resistant and eventually need to be changed.
Without adult supervision...
Also,
Old 06-23-2019, 10:35 AM   #3
Trailer: BigFoot
I have a Big Foot with the vinyls c channel. I also have a Casita.. much prefer the Casita metal band. Looks better and much more durable.
Rzrbrn is offline   Reply With Quote
Old 06-23-2019, 11:05 AM   #4
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Also the Casita belly band can be very useful for hanging various things like lights, cooking implements. etc., and others have designed small shelves to mount on the belly band.
Walt
casita
Burro Trim Lock band on seam Dave Mac Problem Solving | Owners Helping Owners 4 08-20-2015 06:11 PM
Stripping paint from aluminum belly band Cmtravels Problem Solving | Owners Helping Owners 17 03-21-2015 11:06 AM
Vertical Seam Versus Horizontal Seam Cathy P. Care and Feeding of Molded Fiberglass Trailers 17 03-17-2015 11:25 AM
T-Cap for seam on a Trillium Legacy Posts Problem Solving | Owners Helping Owners 5 07-04-2003 09:40 AM
Seam sealant tape on early Scamps Legacy Posts Problem Solving | Owners Helping Owners 2 04-04-2003 08:16 AM
