anode rod - Fiberglass RV
Old 08-07-2007, 05:17 PM   #1
Trailer: Casita 17 ft Liberty Deluxe
I am in the process of replacing the anode rod in my Suburban water heater. I have removed the old anode, flushed the tank, cleaned the threads where the anode goes and wrapped the anode threads with Teflon tape. The anode seems very difficult to return to its place. I do not want to cross-thread the rod and tank. Have you found it difficult to screw the anode back in?
Jim Johnson
JHJohnson is offline   Reply With Quote
Old 08-07-2007, 07:55 PM   #2
Herb P's Avatar
Trailer: Boler 1700SGH (Stage II twoftitis)
This mirrors exactly my anode replacement story... First, it took 2 scraped knuckles, a bloody thumb, and a blue thumb nail to get the old one out. After repeated soakings with a bolt-out and a lot of back/forth and some preheating with the flaming hacksaw, it finally came out... Then drained the tank, cleaned the threads and wrapped new in teflon tape... It seemed as though it barely went in... I made a mental note to check it once I pressurized the water system... Well, it didn't leak.. So, all's good... Don't know why it barely went in but it definitely was _not_ cross threaded... Maybe the new anode has a different taper of pipe thread?
Here's the old one, still had some life in it:
http://www.beer.org/gallery/Boler17-refresh/IMG_5424
One thing I was (and still am) concerned with was whether application of teflon tape was going to destroy conductivity with the tank... No point having the anode if there isn't an electrical path to the tank... But the old anode, which as you can see was quite clearly eaten away, had evidence of teflon tape.
Herb P is offline   Reply With Quote
Old 08-07-2007, 07:59 PM   #3
I called suburban today because we couldn't get ours out after rust away and alot of elbow grease. It very well could have been the original one.
suburban said to use telfon tape. Their customer service is excellent. Got a call back in about 3 minutes. Amazing.
tracy.c is offline   Reply With Quote
Suburban hot water heater anode difficult to install Steve M. Problem Solving | Owners Helping Owners 7 05-25-2009 07:22 PM
Anode Rod for heater.. Christi V. Care and Feeding of Molded Fiberglass Trailers 4 04-20-2008 09:25 AM
An ideal anode removal tool Legacy Posts Modifications, Alterations and Updates 4 10-28-2002 01:38 PM
Anode Rod winterizing question? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 15 10-18-2002 09:03 PM
