Another flooring inquiry - Fiberglass RV
Old 10-27-2011, 10:44 PM   #1
redwine's Avatar
Trailer: Ventura 1974
New door is installed, new foam and upholstery in the works.
Next step is new flooring. Original plywood floor is covered with linoleum, and the intention was just to replace the linoleum.
However, the floor is slightly soft to walk on, and removing the old linoleum (was not glued on) revealed some wetness across the plywood. I drilled out a piece of the wood and it is a bit wet, although it appears fresh.
We think the water has come from the old leaky door, so hopefully there will be no more.
Now the question is what to do with the wet plywood? Do we need to replace it, or can it be fixed?
What can we do to add some stiffness to the floor before installing the new linoleum?
redwine is offline   Reply With Quote
Old 10-28-2011, 12:18 AM   #2
Roger C H's Avatar
Smile Damp Plywood
Welcome to FGRV!
Can you view the rating stamp of the plywood? If it is marine plywood, or exterior grade, the glue should not let go. I would run a dehumidifier in the egg until all trace of moisture is gone, then check the plywood for soundness, and, if it passes, seal it on all six sides before placing or replacing any linoleum.
To be really safe, I would be tempted to just replace the stuff with the proper grade. Be prepared to part with some cash for Marine Grade.
See this for grade examples:
Softwood Plywood Grades
Here is a good discussion of marine plywood:
http://www.duckworksmagazine.com/03/...abbs/april.htm
Good luck.
Old 10-28-2011, 05:56 PM   #3
Here's what I've seen done in houses, at least at friend's house. He had long time leak that ran under the kitchen linoleum. The flooring guy simply removed the linoleum and let the floor dry out. It took almost a month and he used a wood moisture meter to tell when it was dry enough. You could probably rent a wood moisture meter if you don't have one.
Old 10-28-2011, 08:03 PM   #4
Trailer: 84 16 ft Scamp
Our Scamp had a similar problem. One difference was the linoleum was glued down. The problem is that water can't evaporate up through the linoleum, nor down because the plywood is coated with fiberglass resin.
So I removed all the vinyl linoleum, then painted the floor with a gray latex floor paint. We kept it this way for a couple of years, fixed all the leaking rivets window and door frames. I replaced any plywood areas that were still soft and repaired a damaged wheel well, then sanded the floor well with coarse sand paper and coated it with 6 coats of Spar Urethane over several weeks sanding between each coat. This sealed it well, filling all the plywood grain pores. All plywood smell was also eliminated.
Then I installed Allure (tm) flooring in an Oak print.
For myself, I would have just gone with a painted floor, perhaps a gray floor enamel, then used small rugs where desired. However, the oak Allure really dresses things up and is easy to maintain. I was reluctant to go back to a system that could trap moisture, though. But so far -- so good.
Old 10-28-2011, 09:56 PM   #5
redwine's Avatar
I guess the biggest problem for us in this regard is that we are forced to have the trailer stored in a yard where we do not have easy access to power.
Without being able to run a heater, and considering the wet, cool climate we have in BC this time of year, I'm not sure the wood will dry at all?
Inquiry RE Classified FrancesM General Chat 21 04-02-2009 03:21 PM
flooring cyndi H Modifications, Alterations and Updates 1 09-30-2006 08:37 PM
Flooring General Chat 0 01-01-1970 12:00 AM
Flooring Classified Archives 0 01-01-1970 12:00 AM
