Old 02-19-2009, 07:55 AM   #1
Trailer: Home Built Teardrop and U-Haul and Scamp
I did a search and couldn't find much on building a new regular type frame for a 13' scamp,I know it would probably change the center of gravity a bit,but this thing sits so low I was wanting to get it up off the ground a little bit,I know I can get a new axle and raise it but I really want to change the frame and have room for a tongue box and other things ,Any ideas on the problems I might face. Bill
Bill D is offline   Reply With Quote
Old 02-19-2009, 08:23 AM   #2
DanPatWork's Avatar
Trailer: 88 Scamp 16 ft
The first problem you will run into with a frame for a scamp is that it isn't a standard straight frame. The frame makes dips for the floor area at the door. A custom frame to fit the existing frame thus giving you a lift as well as supporting an older "weak" frame might be the way to go. Otherwise you might consider taking the body off, and then having a newer frame made to fit the dimensions of the old one. By the time you get to considering replacing the frame all together your already in the realm of unlimited possibilities in my opinion.
Whatever way you chose to go about your project, please take lots of pictures, and keep us informed.
DanPatWork is offline   Reply With Quote
Old 02-19-2009, 08:40 AM   #3
Pete Dumbleton's Avatar
Simplest way to get some ground clearance for the body is to have a spacer welded between the axle bracket and the frame.
If I were doing that, I would also get the Dexter weld-on bolt-on bracket inserted there -- That would allow a future axle replacement as a bolt-on job with no welding required.
Old 02-19-2009, 09:42 AM   #4
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
Talking
YUP---- and then while consulting your welding expert ask him about reinforcing the frame at the same time. A few simple trusses will add a lot of strength w/o adding much weight. Larry
Larry&Carrie is offline   Reply With Quote
Old 02-19-2009, 02:54 PM   #5
Trailer:
Here are three photos someone kindly sent me of Scamp frames, so you can see what you would be trying to replace.
So to replace the frame, you would also be replacing most of the floor that is screwed to it plus building a new support for the dropped floor area just inside the door. Building a new trailer might be easier!
Andrew
Old 02-19-2009, 05:06 PM   #6
Thanks for all the great info,I'll take plenty of pics when I start this project,I feel I don't have a whole lot to loose with this project,this camper is in poor shape to begin with and I don't have a great deal of $$ invested in the camper itself and I also work at a local high school with a tremendous weld shop. If I can get the old frame off, I'm sure I can get a new one matched to my specs. Bill
Old 02-19-2009, 10:35 PM   #7
Roy in TO's Avatar
Search for other frames too. The boler and similar trailers have similar frames. There are some good pics on this site.
I put 2 short propanes and a battery under a tongue box on mine, all on the stock frame. I'm in the middle of composing the post for raising the body and swapping the axle from leading arm to trailing arm. I hope to get that posted with links in my thread Restoring Our 1972 Boler American, Annotated pictures within the next couple of weeks.
Frame Paint Question DannyH Problem Solving -- Owners Helping Owners 4 11-05-2009 05:16 AM
Need a new Frame :-( ursulap Problem Solving -- Owners Helping Owners 6 07-05-2009 08:28 PM
Frame sag Tom B. Care and Feeding of Molded Fiberglass Trailers 12 01-18-2009 09:14 PM
FRAME JIMZ Care and Feeding of Molded Fiberglass Trailers 53 02-17-2008 10:05 PM
Frame sag Rick Weiss General Chat 0 12-31-1969 06:00 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
