Another scamp wiring question (HELP) - Page 2 - Fiberglass RV
Old 08-15-2015, 04:36 PM   #15
Keaner's Avatar
Trailer: 1973 13' Boler
Green? Typically it's brown coming out of the 7pin. Do you have a voltmeter? It may be that someone wired them in series rather than parallel in which case it could be anywhere. Start checking for 12v between hot and frame at each light. When you can't find it you're in the right ballpark.
Keaner is offline   Reply With Quote
Old 08-15-2015, 07:50 PM   #16
Originally Posted by alan H View Post
Ok so doing some checking
I keep blowing a truck fuse (30a)
Which is listed as trailer sub battery
So far that is as far as ive gotten
Per scamp the blk is for 12 v int lights& acc
Yellow is for brake lights ( foreign stop).....????
You have the trailer battery connected backwards. White wire to the negative terminal and black wire to the positive. That is unless some shade tree mechanic changed the trailer wiring.
Old 08-15-2015, 08:12 PM   #17
Trailer: 2000 17' Casita Freedom Deluxe...Tow vehicle 2015 Toyota Tacoma Dble Cab V6 Prerunner
Byron
Thanks they were switched
Now however when i turn on either directional signal my side markers will flash.... Since they are tied to my running lites I'm making some progress
Kinda wondering if i got the wrong info on bulbs as i was advused that the top socket is single element and both is a double when i have them in that position I don't get any directional signal but when i have the top bulb(double element) i get flashers/ brakes/turn signals everything except running lites
The plot thickens film at 11 ( cause i ll be still trying to figure this out lol)
alan H is online now   Reply With Quote
Old 08-15-2015, 08:51 PM   #18
Byron
The bulbs in the trail lights should NOT be able to fit in the wrong socket. However, to check look at the bottom of the bulb and inside the socket. One of the sockets and a bulb should have two contacts, the other socket should have a single contact and the matching bulb only one contact.
FYI... Terminology the term running lights is the term often used for the side marker lights. The associated light in back is most often referred to as the tail lights.
Once you get the lights all sorted out, be sure and check or have checked your alternator in the tow vehicle. It's been known to happen, a reversed battery killed at least one alternator I know of.
Old 08-16-2015, 12:04 AM   #19
Flashing marker lights
If you figure out how to make the marker lights flash with the turn signals, let me know 'cause I think that would be nice
Frank F
frankcfx is offline   Reply With Quote
Old 08-16-2015, 10:43 AM   #20
Update
While still trying figure this out
I have rewired the origin 4 pin connection and have running/brake/ stop lights( previous owner Never used the brakes)
So having said that i found trailer battery was wired backward and using double element bulbs( in correct socket per previous post)
It would seem all i have to connect would be
the blue( brake wire)
The black ( int 12 v)
Yellow(foreign stop)
Now what this really has me confused
Still unsure about the yellow and black wire
Old 08-16-2015, 11:12 AM   #21
Keaner's Avatar
Alan, take a look at the diagram on this page.
http://www.etrailer.com/faq-wiring.aspx
This is how it should be wired if you follow the wiring colour code as per your 7 pin.
Old 08-17-2015, 10:21 AM   #22
Finally got it figured out
Two issues
1) trailer pkg was not wired properly ( per dealership)
2) found that the 7 pin adapter was defective
What a troubleshooting nightmare
Old 08-17-2015, 02:10 PM   #23
Trailer: 77 Scamp 13
So Alan it is all straightened out? That would be great.
Are you saying the dealership determined that pkg was not wired correctly by a 3rd party or are you saying the dealership messed up?
Old 08-17-2015, 04:30 PM   #24
I m saying the factory installed tow pkg was bad
Need some help with wiring on 1986 Scamp montanascamp Electrical | Charging, Systems, Solar and Generators 12 05-31-2013 10:05 AM
Another Wiring Problem daggo Problem Solving | Owners Helping Owners 18 06-12-2012 05:05 PM
Another Scamp question HustonFamily Problem Solving | Owners Helping Owners 1 08-03-2007 04:21 PM
Scamp to Subaru trailer wiring - help needed Mikeny Problem Solving | Owners Helping Owners 7 07-27-2007 05:16 AM
Need help on wiring new side lights, old scamp Drew Bogner Problem Solving | Owners Helping Owners 6 07-18-2006 06:44 AM
